Old 07-20-2010, 11:08 PM
PearlieSVX PearlieSVX is offline
Removing ABS
I am wanting to take out my abs system...
to do this should i just take out the main unit and all the brake lines ran from the master brake cylinder to the abs unit and then to each brake?
And to reinstall brake lines, would i just run brake lines from the master brake cylinder to each brake?
Help me out.... thanks
Old 07-20-2010, 11:14 PM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: Removing ABS
i cant remember how my friend did it in his 240 but i would just connect the lines where the abs unit was to save on the hassle
Old 07-20-2010, 11:20 PM
Re: Removing ABS
what do you mean where it was? like where it was on what?
Re: Removing ABS
There are 2 lines going into the ABS pump. One goes to FR and RL, the other goes to FL and RR. Get a flare tool, 2 "T's", and 6 compression nuts. Rebend some of the lines and do all the connections right up where the pump used to be.
Old 07-20-2010, 11:23 PM
Re: Removing ABS
and just connect them to the lines comin from the master cylinder?
Old 07-22-2010, 06:54 PM
sowise sowise is offline
Re: Removing ABS
I think I get what you are trying to do but not sure why. Even older cars without ABS had proportional valves to make sure you had the proper brake fluid line pressure going to the fronts vs the rear brakes. It also might make your brakes feel pretty soft and ineffective. However, if I get what Hocrest was saying I think he was saying remove ABS pump, you should have the 2 lines that go to the master cylinder. Take one line and connect it using a t fitting to the lines originally connected to the pump marked FR & RL (Front Right and Rear Left) then take the other line coming from the master cylinder and using another t-fitting connect it to the other remaining two lines FL and RR.
