Old 07-12-2010, 12:41 PM
Dayton-Dave Dayton-Dave is offline
Dayton-Dave
How to get the hood emblem off
I have a new JDM emblem coming....how do I remove the existing hood emblem?
It looks like I might have to take off the hood latch to get to some nuts on the inner part of the hood. Or is it just two face taped on with some locator pins?
Old 07-12-2010, 12:57 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: How to get the hood emblem off
I just used a little plastic spatula from a hobby store to pry it off. The old adhesive was so brittle it popped right off. I t appears the holes are just for alignment.
Gene
Gene and Ben
Old 07-12-2010, 01:18 PM
No bolts on the emblem.
Just take off the two bolts for the hood latch. You will see three pins, each surrounded by a yellow plastic grommet which holds it in place tightly, in addition to the adhesive.
Insert a small screwdriver into the hole and push on the pins to remove the emblem. If the grommets remain in the holes, remove them as there are new ones on the new emblem.
Clean the surface of the hood, peel off the adhesive backing, line up the pins and grommets with the holes and push firmly to seat the emblem completely.
Old 07-15-2010, 08:00 AM
Dayton-Dave
Thats what I needed to know....thanks for the detailed info.'
