Old 07-07-2010, 04:47 PM
processengr's Avatar
Windshield trim question: trim problem
Hi all,
My daughter had windshield replaced today in the Ebony 92. Joint dealer/local shop replacement of replacement; in that the 1st factory windshield pressure cracked after three days. Local Glass shop chased Subaru dealer for warranty on glass...the 1st was replaced in May. At this point I feel I need to fix this myself...Trim does not sit right. How to fix...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 07-07-2010, 10:37 PM
Manarius's Avatar
Manarius Manarius is offline
Re: Windshield trim question: trim problem
What piece of trim is that? No SVX I've ever seen has a piece of trim right there. It just goes straight from windshield to the black piece that the wipers sit on.
-Jason
-Obi Wan Kenobi
Old 07-08-2010, 02:15 AM
All SVXi have it as far as I know, mine does
Old 07-08-2010, 08:12 AM
The problem pictured above is relatively minor and common in MANY cars after a windshield installation.
Gordon, did you see if the tech took the wipers and cowl off the car?
There is a common practice/shortcut with many installers called "sneaking" where they will leave on the wipers and cowling when doing a windshield install, in order to save time, and avoid the hassle of removing parts such as wiper arms, wiper cowls, etc. This practice is frowned upon "by the book" because an inexperienced tech will run the risk of making a poor seal, yet many installers still use this technique to avoid damaging costly items in removal/installation.
Sneaking often leaves cowl panels either slightly deformed or unclipped.
This will not affect the seal of your windshield, but will allow debris to collect in the cowl drains.
In this case, I'd take a peek under the metal trim and see if any of the white clips are missing, broken, or just not clipped in. A small push on the cowl may do the trick.
Old 07-08-2010, 02:05 PM
Manarius's Avatar
Hmm, I'd need to see a picture of that from a different angle. If it is where I think it is, my car only has black glass there.
-Jason
-Obi Wan Kenobi
Old 07-08-2010, 02:51 PM
Unless you can see your wiper linkage, your car has that metal cowl piece.
Old 07-08-2010, 05:39 PM
Hi Mike!
I was not able to deliver the car or be there, daughter handled replacement of replacement. The first windshield the cowl was installed perfectly, but they left the drivers side wiper loose, so they probably removed them. This time, it was apparently installed at dealership the 1st windshield was purchased from, due to warrantee claim.
Mike, does the cowl remove easily? I would like to take it off and refinish it, if it does.
Cheers! Gordon
2018 Tesla M3 30k
