Old 07-05-2010, 12:00 AM
92_LSL's Avatar
92_LSL 92_LSL is offline
sea foam treatment
exactly what is a sea foam treatment and what dose it do ?
I has teh FWD LS-L
Old 07-05-2010, 12:09 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: sea foam treatment
Its basically a all-in-one cleaner for your engine. You add it to your oil, fuel, and directly into your intake and it cleans gunk from your intake passages, injectors, engine parts, etc. Many here have used it with success for symptoms like rough idle and poor gas mileage. It can be scary when you use it in your intake directly as your car smokes like crazy, but it clears up and makes it run smoother in most cases. Check it out here.
If you do use it in your oil, make sure you change it after the cleaning cycle is done. Do NOT drive the car with the Seafoam still in the crankcase.
Old 07-05-2010, 03:08 PM
92_LSL's Avatar
that stuff seems great. i have gunky crap in the intake manifold and i want it gone. i'm planning to do a full tune up and engine cleaning.
I has teh FWD LS-L
Old 07-05-2010, 03:10 PM
Gamesy's Avatar
Gamesy Gamesy is offline
i've used it, works great but prepare to make a smokescreen behind your car.
Old 07-05-2010, 07:00 PM
92_LSL's Avatar
it's that bad ?
I has teh FWD LS-L
Old 07-05-2010, 07:17 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Originally Posted by 92_LSL View Post
it's that bad ?
Nope just a by-product of the crap being burnt away in your cylinders. Check out Youtube for what to expect.
http://www.youtube.com/watch?v=8MDMFhOPHGY
Old 07-05-2010, 08:22 PM
92_LSL's Avatar
damn. so has anyone noticed any considerable gains from this ?
I has teh FWD LS-L
Old 07-05-2010, 11:41 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Car ran a little better, idle smoothed out. As far as power I didnt feel anything different.
Old 07-05-2010, 11:46 PM
Gamesy's Avatar
the car's not so rough afterwards, and i did get some better mileage
Old 07-06-2010, 11:13 AM
92_LSL's Avatar
one last thing, is it true that if you put to much you can hydro lock your engine ?
I has teh FWD LS-L
Old 07-06-2010, 11:56 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Nearly impossible.... you add thru a vacuum port, so it would be next to impossible to draw in that volume of the Seafoam to fill up a cylinder on one intake stroke.
Old 07-06-2010, 04:21 PM
92_LSL's Avatar
well thanks for all the info guys, it really helped me understand it a little more.
I has teh FWD LS-L
