Old 06-29-2010, 03:53 PM
The1One1AndOnly The1One1AndOnly is offline
Is This A Fuel Pump Issue?
My 92 chokes sometimes and jerks back and forth, and sometimes dies from it when giving it more gas.
Mechanic quoted that it was a 90% fuel pump issue, before i get it replaced any other thoughts on what the issue might be?
Thanks
Old 06-29-2010, 04:20 PM
ZMan's Avatar
ZMan ZMan is offline
Re: Is This A Fuel Pump Issue?
Change your fuel filter first. - Ed
http://www.ehow.com/facts_5125417_si...el-filter.html
http://www.buzzle.com/articles/signs...el-filter.html
Old 06-29-2010, 05:07 PM
Thanks
Make sure that the fuel pressure has been properly checked before accepting this as a definitive diagnosis. Otherwise a guessing game could prove costly.
The pressure should normally register as between 34 - 38 psi or 235 - 265 kpa.
Old 07-02-2010, 12:44 PM
Ok, thanks a lot for the info.
In general what else can cause such an issue?
Old 07-02-2010, 01:06 PM
ZMan's Avatar
Did you change the filter and check the pressure yet?
Old 07-02-2010, 08:13 PM
Manarius's Avatar
Manarius Manarius is offline
When my MAF failed on my Legacy, it had all sorts of strange behavior, including the behavior the OP mentioned. I would check that out too. Find someone nearby who has one that works, swap and see if the behavior goes away.
-Jason
-Obi Wan Kenobi
Old 07-02-2010, 11:34 PM
XT6Wagon XT6Wagon is offline
More likely to be a sensor issue than a fuel pump issue.
Fuel pump issues usualy manifest as issues at higher rpm if they are not putting out the flow/pressure.
Old 07-03-2010, 10:45 PM
Car is gonna be ready on Monday, so i will definitely let you know what the problem was.
The response I am getting from the mechanic is that it is fine now, and that it was a fuel pump/filter issue, will let you know once i drive it for sure.
Thanks for the help.
