Old 06-27-2010, 07:54 PM
robert_the_sane robert_the_sane is offline
weird surging
My pearl started surging tonight, very odd...seems almost like it's starving for fuel...until I press the throttle. Then everything's fine
Only does it at very low speeds and only very light throttle...and only when everything is up to normal temp...
Any ideas folks?
'94 SVX Ls-I
Old 06-27-2010, 09:05 PM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: weird surging
I'm gonna go with TPS or a dirty MAF
Old 06-28-2010, 12:43 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: weird surging
Id say a possible TPS problem too, but id run a good fuel injector cleaner thru first, just because. Then if it doesnt help you can go on to other, less simple testing.
Old 06-28-2010, 06:27 AM
Re: weird surging
What brand fuel injector cleaner do you recommend, I never know what to get?
Old 06-28-2010, 08:19 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: weird surging
The one that has worked the best for me is the "Guaranteed to pass" one that you use before a smog check. Might also be helpful to run Seafoam thru the intake too, our PCV and EGR systems run a lot of crap back into the intake chambers.
Old 06-28-2010, 10:52 AM
Prophet john Prophet john is offline
Re: weird surging
tho only other thing i can think of is the maf is fighting with the ecu. check for cracks or leaks in the plastic between the maf and the plenum.
had this problem with my 89 celica... toyota dealer basically charged me $80 for three feet of clear packing tape... i was pissed!
Old 06-28-2010, 12:59 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: weird surging
Oh almost forgot, you should resistance check your coolant temp sensor.... when they go bad they cause all sorts of weird crap... including timing & mixture issues.
