Old 06-20-2010, 06:51 PM
Green1995SVX's Avatar
Transmisson TCU Code 25?
Admittedly, I probably don't drive my SVX as much as I should. Yesterday I had to move it (from the right side of the garage to the left - quite a journey.) The battery was dead. After I jumped it, I got a flashing power light at startup indicating a stored transmission code. Upon initiating the procedure to read the codes, I received code 25. Two long flashes followed by 5 short flashes. According to the chart, this is not a valid code. I am no longer getting the flashing power light at startup.
Does anybody have any idea as to what is going on here?
Any insight to this minor mystery would be greatly appreciated.
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 06-20-2010, 07:05 PM
SVXTREM's Avatar
SVXTREM SVXTREM is offline
Time to let the SVX out!
Send a message via AIM to SVXTREM
Re: Transmisson TCU Code 25?
From svx-iw.com:
Trouble codes:
11 - Duty solenoid A
12 - Duty solenoid B
13 - Shift solenoid 3
14 - Shift solenoid 2
15 - Shift solenoid 1
21 - ATF temp sensor
22 - Atmospheric sensor
23 - Engine revolution signal
24 - Duty solenoid C
25 - Engine torque control signal
31 - Throttle sensor
32 - Vehicle speed sensor 1
33 - Vehicle speed sensor 2
Old 06-20-2010, 07:08 PM
Interesting. Does anybody have any idea why I would have gotten that code?
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 06-20-2010, 07:42 PM
Cam Cam is offline
If the signal comes from the ECU it could have taken a few moments for it to register since the ECU could likely have ditched its memory on a dead battery.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 06-20-2010, 07:44 PM
25 - Engine torque control signal = You're not driving me enough and my torque is wasting away in your garage...
Old 06-20-2010, 07:45 PM
Cam Cam is offline
+1
Cam
'92 Ls-L Dark Teal
Old 06-20-2010, 07:57 PM
Mike
Kia ora Mike,
Jumping the battery could have caused a voltage spike which the TCU randomly read as a fault. In the event that after the memory has been cleared the code no longer registers, forget it.
If the code remains as permanent, let us know if you have any form of shift kit fitted. The signal involved relates to a fault in a link between the ECU and TCU.
Cheers, Trevor.
Old 06-20-2010, 08:35 PM
Originally Posted by Trevor View Post
Kia ora Mike,
Cheers, Trevor.
Thank you for the explanation, Trevor. I am going out of town on business for the first part of the week, but when I return I will drive the car to my office and back to make sure the code doesn't return.
Thanks again!
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
