Old 06-17-2010, 11:33 AM
juice's Avatar
juice juice is offline
Juice
Talking Factory alarm
I have a 96 and it won't start and the security light keeps coming on it did the same thing the other day and I got it to start after messing with it a while. Any ideas how to reset or even turn it off. I disconnected the battery but still the same.
Old 06-17-2010, 01:56 PM
Re: Factory alarm
Maybe this help? See Attached.
Old 06-23-2010, 02:21 PM
mtgulo's Avatar
mtgulo mtgulo is offline
1992 SVX LS-L Proud Owner
Send a message via AIM to mtgulo
Re: Factory alarm
I am having a problem where the alarm is going off no matter what I do. I do not have the remote and I have tried all ideas that people have been so kind to offer. So, I had to disconnect the horn to keep it quiet and disconnect the battery when not in use. Can anyone tell me where I can find the security module so I can rip it out. I am planning to put a new alarm system in later anyway.
As Always, thanks for all the help!
Old 06-23-2010, 02:53 PM
Re: Factory alarm
maybe this help? see attached:
File Type: pdf HOW TO - After Market Alarm Install (31801).pdf (243.2 KB, 117 views)
Old 06-23-2010, 03:18 PM
mtgulo's Avatar
Re: Factory alarm
Thanks but that does not show me where the brains of the alarm system is. I need to somehow completly disable the alarm system without interfering with the electronics and starter!
Old 06-23-2010, 03:34 PM
mtgulo's Avatar
Re: Factory alarm
Woops, responded before reading the second attachment. Do you know if I pull the connection on the big or small box if that will disable the alarm?
Old 06-23-2010, 03:38 PM
Re: Factory alarm
I have no idea what plugs do what.
Brain location is in that first PDF on page 2, listed as "electronic module".
Old 06-23-2010, 03:57 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Factory alarm
You did the parking light switch thing to deactivate it?
After doing so, you should be able to just press the security button once to turn it off, so you dont have to "rip" anything out of the car.
