Old 07-31-2010, 07:56 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Bouncing Rev Counter
Originally Posted by JMan69 View Post
Outta curiosity wat is the small looking sensor right next to the coolant temp sensor? And what does it do? Cheers
Thats the coolant temperature sender, it controls the reading of the gauge in the dash.
Old 07-31-2010, 09:25 PM
JMan69's Avatar
JMan69 JMan69 is offline
Jay
Just about to replace it now. I'm going out to go get a deeper 19mm socket. I tried the crow's feet spanner that I used for the PCV value but there wasn't enough room for movement. So just for the record a deep 19mm socket will do the trick.
Old 07-31-2010, 09:42 PM
JMan69's Avatar
Jay
Sorry to keep asking so many questions. Why did this sensor fail? My svx has only 155,xxx kms.
I appreciate all your help on this matter mate
Old 07-31-2010, 10:38 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
You can ask all the questions you want.... most all in this forum are here to help.
Its not really a matter of mileage..... more of an age issue. Most thermistors tend to fail after some length of time or # of cycles, it just happens.
Old 09-22-2010, 12:05 PM
Huskymaniac's Avatar
Uses the ignore feature
JMan,
Did replacing the temp sensor fix your bouncy idle at startup?
Tony
Old 09-23-2010, 10:23 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Out of curiousity, should this be an item to replace every 5 years or so on the vehicle just for preventitive maint.?
1995 Subaru Svx L / AWD
Old 09-23-2010, 12:26 PM
kwren's Avatar
kwren kwren is offline
probably not...
I have one SVX with 200,000+ that has never needed one...
Keith
Old 10-08-2010, 11:29 PM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
Bump...
I would like to know if it fixed it as well, mine does the bouncy idle every once in a while. I will check my codes tomorrow for the temp sensor. but I KNOW that I have o2 sensor code.
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 02-21-2011, 04:22 PM
sd2649's Avatar
Driving in Style
bought engine temp sensor... gonna find out now... 4 months later...
-Steven
SOLD
Old 02-22-2011, 10:10 PM
sd2649's Avatar
Driving in Style
Worked like a champ, no more hard starts and no more bouncy rev counter!
-Steven
SOLD
