Old 07-14-2010, 10:41 AM
laserx's Avatar
laserx laserx is offline
Can you use any year transmission
Can you use any SVX transmission from any year car....like a 92 or 94 in a 96. as a replacement?
1996 Black, 134,000 KM, with Custom Stainless from Headers to Stebro, 17" Wheels, Michelin Pilot Sport PS2 225/45/17 Cold Air Intake.
Pioneer AVIC D3 GPS/Video/Sound/Sirius/Bluetooth/USB
Koni struts/ground control coilovers
Stainless steel brake lines
K&N filter, custom front grill
H.I.D low beams 5000k 35w, H.I.D fog/driving 4500k 35w
Clear front and corner lens
Old 07-14-2010, 10:58 AM
Re: Can you use any year transmission
Any year SVX transmission is a direct replacement,
Old 07-14-2010, 11:20 AM
laserx's Avatar
Thank you very much.
Old 07-14-2010, 11:56 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Id try for a later year if possible... stay away from the 92's.
Old 07-14-2010, 12:04 PM
laserx's Avatar
I found one in New Hampshire for $400.00, with 80k miles on it, but in "excellent condition". I just need to get it brought to Toronto, still trying to find out what year car it's from.
Old 07-14-2010, 12:05 PM
longassname's Avatar
Just some dude.
Significant Technical Input
Just in case you aren't aware I have very affordable rebuilt and upgraded transmissions. Last time I shipped one to canada freight was about $500.
http://www.ecutune.com/4eat.htm
Old 07-14-2010, 12:30 PM
Not to nitpick but just to avoid confusion to anyone who would see this, even though it would appear obvious, a FWD transmission can only be used in an AWD car if you choose you don't want AWD anymore.
Old 07-14-2010, 12:46 PM
Actually you can bolt all the AWD parts and wiring into a FWD tranny to make it an AWD, but they run a different final drive ratio, so you'd also need to change out the rear diff...
Old 07-14-2010, 01:07 PM
Very true, but then it isn't so "direct"
Old 07-14-2010, 01:37 PM
laserx's Avatar
Perhaps this would be a better way to go to avoid having to do this all over again in the near future. I know nothing about transmissions (except this is the 5th one between two SVX's), how would I choose which gear ratio to get? If you can explain the difference between each I'd appreciate it. This is now sounding like my best option.
Old 07-14-2010, 05:08 PM
laserx's Avatar
In talking to my son, he told me the 4.44 would make the car faster? Would I also have to change the rear diff? The tranny in NH is from a 92, think I'll pass on it as it will go very soon, my 92 went through 3 of them in 450,000km, it's now a 5 speed.
Old 07-14-2010, 05:56 PM
Just some dude.
If you get a transmission with anything other than the SVX OE 3.545 gear ratio you would have to get a rear differential set up with the matching gear ratio. I personally prefer the OE 3.545 gear ratio. When coupled with one of my performance transmisison control units (TCU) most people agree. The SVX doesn't really need a higher gear ratio to get better acceleration; it needs the better shift maps I put in the performance TCUs. The higher gear ratio is really only beneficial for drag racing.
In their stock form the non SVX transmissions have a couple clutch packs which are weaker than what's in the SVX transmission; however, when ordered from me the transmission will be upgraded to the same much stronger than original equipment setup no matter what the gear ratio.
My preference and my advice is to stay with the original 3.545 gear ratio and get a performance TCU to match.
Old 07-14-2010, 06:29 PM
The external speed sensor on the AWD transmissions also needs to have the wiring changed over...
Old 07-14-2010, 07:47 PM
Probably should mention that you should avoid the JDM transmissions.
