Old 07-13-2010, 07:55 PM
nexus_7 nexus_7 is offline
Question can I swap out my abs unit under the hood?
My current one is leaking and I have a donor car here that I could swap it with maybe? Or is it a major issue because of the solid break lines?
Thanks
Greg
Old 07-13-2010, 08:29 PM
sowise sowise is offline
Re: can I swap out my abs unit under the hood?
Don't see why you couldn't, are you certain yours is failed?
Definitely download the svx manual from the site as well.
Old 07-13-2010, 08:47 PM
not failed, failing. lol
anyone have any experience with this?
Old 07-13-2010, 09:22 PM
yes it can be done... Make sure you bleed the system out thoroughly
Old 07-14-2010, 06:22 PM
+1 the manual walks through the bleed procedures as well as troubleshooting. Just curious did you check your ABS system for trouble codes?
Old 07-14-2010, 06:36 PM
its leaking...no need for a code.
Old 07-14-2010, 06:43 PM
I didn't catch mine in time and ended up rear ending someone (low speed) because of it... Get it taken care of ASAP
