Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #76
Old 11-25-2012, 05:04 AM
steveherman steveherman is offline
Re: ECUtuner software and Select Monitor Interface
Originally Posted by longassname View Post
Alright, on the ECU chip performance TCU combo I will do a $20 refund.
I can't really afford to discount select monitor harnesses on their own but I'll give a $5 refund on them so nobody feels left out.
Hopefully my first paycheck after christmas.
I want the ecu and the tcu ...
fingers crossed I am excited.
Old 11-25-2012, 07:32 AM
longassname's Avatar
Just some dude.
Same thing, download the firmware and email it to me. I'll tell you where some stuff is and you use the communications test box on the setup tab of the ecutuner software to send a write command to a non-volatile memory location like a fuel table cell for the ecu or a shift map or temp threshold for the tcu. Then send a read command of the same address and see if it wrote the new value or not.
I have the car tonight, so I can try and do this. Any chance we can get this to work with the TCU as well? How would I go about trying it out?
Old 12-05-2012, 10:13 PM
Just some dude.
Icing and I have been emailing back and forth the last few days. He's now used the ECUtuner software and interface to successfully download the full address space off the ob2 ECU and I have identified the firmware and where all the goodies are.
Old 12-07-2012, 09:31 AM
Guys, really, I don't think many people have gotten this, and it's an extremely useful diagnostic tool. The program itself needs a little bit of polish, but I have been using it quite a bit and found it to be very stable, and to work really well.
Going to try pulling the TCU firmware this weekend and LAN is already going through the ECU firmware.
Here's an example of it's usefulness: The tachometer in my 97 hasn't been working for a couple months now and I haven't had an opportunity to change it. The trans was starting to slip before the tach died, but I wanted to see if it was still doing it, and show my brother what was going on so he could keep it out of the conditions that cause it to slip, and he's borrowing the car for the time being. Not so easy to show someone what slipping looks/feels like without the tach working. Hooked up the SSM-USB cable, fired it up, told the ECUtuner program to monitor address 0009, which is the engine RPM. Works perfectly, and I showed him as we drove around, how the RPM would start to creep up when it shouldn't and that if you keep it in the next gear down, it will prevent that. We'll probably will get another few months of life out of the trans because of it.
Old 12-07-2012, 10:13 AM
powerdog powerdog is offline
I have a stock SVX. Can I utilize this software? Cable was $79 or so?
1994 SVX L FWD
"The Blue Bullet"
Old 12-07-2012, 10:16 AM
Yes you can. Yes, but you also have to order a special USB cable. See here: http://ecutune.com/ECUtuner.htm
Totally worth it, IMO, especially considering the software is free.
As of now, it seems only to be working with 32-bit windows.
Old 12-07-2012, 10:32 AM
Oh, good point. didn't think to ask...as I am 64bit.
1994 SVX L FWD
"The Blue Bullet"
Old 12-07-2012, 10:34 AM
BRZCory BRZCory is offline
I've ran it on 64 bit. No problemo.
I am running into the "92 problem" though, so it's off to Digikey I go for an IC chip!
Old 12-07-2012, 10:38 AM
Oh yea, you got it working on 64-bit? XP, vista, or 7? I could not get it to work, and I tried everything I could think of.
Old 12-08-2012, 01:08 PM
Just some dude.
I'll make a point of recompiling it with the license for saving excel files and to work with 64 bit windows soon. In the mean time I would suggest anyone runing a 64 bit version of windows use vmplayer from vmware to create a virtual machine with a 32 bit windows. (that's how you run another version of windows inside of whatever version of windows you are running.)
Old 12-13-2012, 07:06 AM
Just some dude.
There's still time to get your SVX the ECUtune goodness it needs and deserves for Christmas. The Christmas sales are as follows:
On the ECU chip performance TCU combo I will do a $20 refund (ask for it in the comments of your paypal transaction or send me an email at the time of purchase).
On the Select Monitor interfaces when purchased on their own I'll give a $5 refund.
And the big one is the Stage1Av1 with a select monitor interface for $245 (email me with the address for your paypal account and I'll send an invoice)
Merry Christmas
Old 01-07-2013, 08:42 PM
2006eg33 2006eg33 is offline
this may have been covered, but can you use this for tuning? or is it purely for diagnostics?
Old 01-08-2013, 02:26 PM
So far just diagnostics. There's a chance that the OBD2 ECUs might be tunable, but not yet.
Old 04-12-2015, 01:09 PM
I've been researching SVX datalogging for a few hours now and seem to have hit a brick wall as LAN's website is down.
I saw he is parting out his car. Is he pulling out of the SVX community?
Old 04-12-2015, 09:42 PM
Just some dude.
I'm not parting out either of my SVXs. I'm selling the driveline out of my pearlie which I am preparing to completely redo and make my personal car.
