Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 11-04-2005, 10:03 AM
ECUtune Stage II reviews
Well I figured with the limited amount of Stage 2 users out there, we would try and post of what we think
I love it... The car pulls up though the rpms that used to lay flat or buck. It will also allow me to further modify the engine without having to worry about MAF restriction. Once the new software is available...v5 with the new idle configurations I will be more than pleased... Thanks LAN for a great product and strong tech support with it!!
Old 11-04-2005, 10:18 AM
shotgunslade's Avatar
Can't say definitively whether or not it is stronger than the Stage 1v4. The best characteristic for me is the smoothness of the throttle response. Before I was chipped, if I nailed it at low to mid rpm's, there would be a slight hesitation, before I got full response. Not the case now. It's very strong at low to mid rpm's. If I leave the climate control on, I get the strong response from a dead stop. If I don't, the idle problem gives me a slight hesitation. Since I am 4EAT, I shift at 6400-6500 rpm, so I didn't really detect the MAF max-out with the Stage1v4. Looking forward to seeing how it works when I have a few more mods under the hood.
Old 11-04-2005, 10:38 AM
RSVX RSVX is offline
Network Design Administrator
Stage II is with NOS, right?
Life is a game. Play to win.
Old 11-04-2005, 11:15 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
The very first versions that were released were for Nitrous.
The Stage 2v4 and v5 which ECUTune released uses a Z32 MAF and software to allow the car to make much more hp than stock.
Go to www.ecutune.com for more info.
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-04-2005, 11:56 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Well, having just taken the NASA-funded time machine out for another spin, i can say the following:
"The 2v5 chip with the z32 MAF is the best thing since sliced bread! I can't believe how easy it made it to beat ChikeBob by several car lengths at the Drag Strip! Given the power it unleashes, the 2v5 with the z32 MAF should be left in the hands of the SVX OBD-I owners only!"
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-04-2005, 07:43 PM
Bill, just face it... that puney engine you have won't be able to max the MAF anyway
Old 12-23-2005, 01:26 PM
Just an update for those of you who are curious. My 6 speed just passed Jersey State Inspection the other day with the Stage 2v5 ECU. Figured I would let other's know
Old 12-23-2005, 04:45 PM
SVXRide's Avatar
Tom,
Did the inspection include emissions? If it did, can you post the figures for HC, CO2, etc.
-Bill
Old 12-27-2005, 08:37 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Just an update for those of you who are curious. My 6 speed just passed Jersey State Inspection the other day with the Stage 2v5 ECU. Figured I would let other's know. It only cost an extra Big Ben Franklin!
Fixed your post!
Old 12-27-2005, 09:23 AM
I am not sure that I still have the readouts... I will look for them. No way, i didn't pay anyone... the guy couldn't even find out how to use reverse!!
Old 12-27-2005, 09:57 AM
Tom:
What pressure was your FPR set at for the emissions test? Stock (~35 psi) or higher?
Old 12-27-2005, 09:59 AM
I still have the stock FPR
TOm
Old 12-27-2005, 01:00 PM
ok found my emissions read-out
HC- 22... Standard-100
CO%- 0.00... Standard- 0.50
CO2% 15.1... Standard-...
This is all that is relevant in NJ inspection I guess. Please take not that they only have 2wd rollers so my emissions are based on revs in neutral
Old 12-27-2005, 02:48 PM
SVXRide's Avatar
Tom,
Great! The key here is that you're not even close to any of the maximum allowable levels!
-Bill
Old 12-27-2005, 03:29 PM
I cannot promise the same results to others. People with other than stock exhaust fpr and maybe some busted vaccum lines might have different #'s. I know that my engine runs very well
