Old 09-23-2008, 03:17 PM
Re: Memory dump of ECU
Ok got all the addresses off the 92-96 SVX SSMI
in order of functions on the SSM
F00- 0C3D ( ROM ID NUMBER "YEAR")
F01- 102F ( BATTERY VOLTAGE)
F02- 1071 ( VEHICLE SPEED)
F03- "" ( VEHICLE SPEED)
F04- 106F ( ENGINE SPEED)
F05- 1185 ( WATER TEMP)
F06- "" ( WATER TEMP)
F07- 10A2 (IGNITION TIMING)
F08- 1283 (AIRFLOW SENSOR)
F09- 1282 (LOAD DATA)
F10- 128C (THROTTLE POSITION SENSOR)
F11- 1280 (INJECTOR PULSE WIDTH)
F12- 129D (BY-PASS AIR CONTROL)
F13- 1291 (02 RIGHT HAND)
F14- 1292 (02 LEFT HAND)
F15- 12B0 (02 R MAX)
F16- 12B1 (02 R MIN)
F17- 12B2 (02 L MAX)
F18- 12B3 (02 L MIN)
F19- 1097 (AFR CORRECTION 1)
F20- 109F (AFR CORRECTION 2)
F21- 12A7 (KNOCK CORRECTION)
F22- 12A5 (CANISTER PURGE CONTROL)
F23- 125F (ATMOSPHERIC PRESSURE)
FB0- 1029 (DIAG. READ)
FB1- 12BC (DIAG. MEMORY)
I still need to get the formulas but most are pretty close as is.
Old 09-23-2008, 05:28 PM
genzzel genzzel is offline
Will pass gas for $$
WOW--Great job!!!!!!! Thank you for doing that!!!
Old 09-24-2008, 03:44 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Fantasic Tom!!! Good Work.
Thanks for doing that. How long did it take to get them all?
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 09-24-2008, 07:15 AM
b3lha's Avatar
Phil & Belha
I've just started marking these in the ECU program to see if it makes any more sense now. It will take a while.
I'm pretty sure this one should be 8C3D. Not that it's particularly important.
Old 09-24-2008, 08:23 AM
Phil, it really only took about 10 minutes mostly because my trial of the hex-com tool will only run for 5 mins at a time. That and I hand wrote all of the addresses.
I have double checked all but the ID and the diag. addresses in Evoscan and they all work. I will try and do it to Eric's 96 next chance I get to get those ID's as well since they do not carry over.
Thanks again for all of your help.
Old 10-15-2008, 10:52 AM
OK, got the TCU commands up... I may try to run them in Evoscan today if I can get it.
F01 VB- 45104400
F02 VSP1- 45001900
F03 VSP1- 45001900
F04 VSP2- 45001A00
F05 VSP2- 45001A00
F06 EREV- 4500B600
F07 ATFT- 45001700
F08 ATFT- 45001700
F09 THV- 45104000
F10 GEAR- 45004E00
F11 PLDTY- 4500B300
F12 LUDTY- 4500B400
F13 4WDTY- 4500B500
F14 BAROP.- 45104600
Its a short list of commands but this is what I got from a totally stock 1992 LS-L
Old 10-15-2008, 03:28 PM
Again Great Job!! I have to ask--how will these run in EvoScan?? I am not sure how to do that.
Old 10-15-2008, 04:39 PM
Not sure, didn't touch on them today.. maybe sometime soon though
Old 10-16-2008, 03:51 AM
b3lha's Avatar
Phil & Belha
Thumbs up Re: Memory dump of ECU
F01 VB- 45104400
F02 VSP1- 45001900
F03 VSP1- 45001900
F04 VSP2- 45001A00
F05 VSP2- 45001A00
F06 EREV- 4500B600
F07 ATFT- 45001700
F08 ATFT- 45001700
F09 THV- 45104000
F10 GEAR- 45004E00
F11 PLDTY- 4500B300
F12 LUDTY- 4500B400
F13 4WDTY- 4500B500
Battery Voltage 1044
Vehicle Speed Sensor 1 0019
Vehicle Speed Sensor 2 001A
Engine RPM 00B6
ATF Temperature 0017
TPS Signal 1040
Gear Position 004E
Line Pressure SolA Duty 00B3
Lockup SolB Duty 00B4
4WD SolC Duty 00B5
Atmospheric Pressure 1046
Fantastic Tom! Thanks. That helps a lot.
I can't see a way in Evoscan to change the 78(ecu) command to 45(tcu). I'm going to email Hamish and see if he is willing to include this in the next version of Evoscan. Being able to look at ATF temperature would be particularly useful.
Old 10-16-2008, 07:29 AM
sounds good... The reason I included the 4500 is the fact that a couple were 4510 while most were 4500, i wanted to be sure that this was noticed.
Old 10-19-2008, 10:48 AM
I have written Hamish couple of times and no answer??? If you guys come up with anything or if he puts out version that works with TCU please let me know.
Old 10-19-2008, 05:50 PM
b3lha's Avatar
Phil & Belha
Originally Posted by b3lha
Dear Hamish,
Thanks for all the work you have done to support older Subarus. We in the SVX community are very happy to finally have some good datalogging software for our cars.
Would it be possible for you to support the OBD1 Subaru TCU (transmission control unit) in your next version?
It shouldn't be too hard to implement. The query is exactly the same as for the ECU but you send 0x45 instead of 0x78.
ie. The "read" command is "45aaaa00" instead of "78aaaa00" where aaaa is the address. The "stop" command remains "12000000" just like on the ECU.
The parameter addresses are:
Vehicle Speed Sensor #1 0019
Vehicle Speed Sensor #2 001A
Engine RPM 00B6
TPS Signal 1040
Gear Position 004E
Line Pressure Solenoid Duty Cycle 00B3
Lockup Solenoid Duty Cycle 00B4
4WD Solenoid Duty Cycle 00B5
Thanks.
Phil Skuse.
Originally Posted by evoscan
Date: 2008-10-19 18:53:14
Message:
ok I'll implement that for v2.6. thanks for the info.
Regards,
Hamish Ahern.
Let's hope he does.
Old 11-26-2008, 03:11 PM
Chesked evoscan site today and there is a 2.6beta4 version out--down loaded it but do not see anything for tcu logging
Old 11-27-2008, 01:41 PM
Phil, wondering if you had some insight on the following things
Injector voltage correction time @ the following voltages
10.0v
10.3v
10.7v
11.0v
11.3v
11.7v
12.0v
12.3v
12.7v
13.0v
13.3v
13.7v
14.0v
14.3v
14.7v
15.0v
I know this is stuffed into the ECU's programming, I am just wondering if you have found it.
Also wondering if you have stumbled over the water temp correction maps?Cold start phasing?Cold start Primer?
The voltage correction time is crucial to my writing the base maps to the Nemesis. There is a VERY lengthy and boring procedure that I can do to get the correct values but i would love to avoid them if you have the data already
Old 12-22-2008, 06:31 AM
Mrdjc Mrdjc is offline
Good to see there has been progress in the last few months, I more or less forgot about this whole project!
About the eavesdropping.. Where are you meant to get three female connectors? Strip them out of three cars? I had a look on the Molex website, but to no avail.
Also, can an idiots proof guide be written as to how to eavesdrop?
It looks a bit confusing to me
Also, do you connect it to B35, or to the ECU?
When you refer to SSM, do you mean the scanner available from Subaru?
or another pc with software like VWRX or Evoscan?
What are m and c in your calculations??
Cheers,
Daniel.
