#661
I don't know how the duty cycle relates to torque split on the JDM box. On the USDM box, Nomake is assuming that 95% is FWD because it starts out at 95% and drops on hard acceleration when the TCU is presumably transferring power to the back. You seem to be suggesting the opposite. This discussion is certainly worth having.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
#662
A superb write up as always. This is getting interesting. I hope we can make some sense of it all. I'll try and fix up the software a bit later this week.
#663
Phil,
You are unable to access what is going on if there is confusion between what happens as a result of a control signal energising or alternatively de-energising a device. If your expectations are back to front you will be looking for a paddle. Sincerely, Trevor.
#664
The US gearbox is essentially a FWD box with rear assist, Subaru calls it the Active Torque Split AWD box, although a very clever and effective rear assist, unlike the rubbish from Honda and others. The JDM/EU gearbox is the fulltime AWD box, they call this the VTD-AWD box, and is biased [around 65% if memory serves] to rear drive before the TCU starts sharing torque around. Now if you take both these vehicles and give them a hard launch, you should get exactly what you are describing here; Trevor's jdm being rear bias, if it loses traction at all it will likely be at the rear, so the computer will shift the torque to the front to eliminate slip. In the US car, it starts off front biased, if you launch it hard the front wheels will lose grip, and the computer shifts torque to the rears to avoid slip. Two differently biased systems, they have to work in opposite directions where slippage occurs. Joe
#665
P.s.
Phil,
Re the question i overlooked --- On the JDM box a signal providing maximum energised time and current in respect of normally open solenoid C, will increase front rear drive to virtual lock up. You can prove this by inserting the control fuse. Useful if you get stuck in the mud. The US arrangement with a normally closed C solenoid, reduces pressure by opening the solenoid and consequently the clutch is not operated and there is no front wheel drive. Proven because a faulty C solenoid results in lock up. This arrangement prevents the need for mechanical alterations in respect of the hydraulics used in the two systems, as was proposed some time ago by Harvey. I trust that you now are aware just why solenoid operation must be correctly understood. Bringing up trivia was certainly not in my mind.
#666
I'm having trouble getting my head around this, so I'm going to quote something from the USDM manual.
When the car is in FWD mode. No power to the rear, solenoid C is fully energised. A high duty cycle (100%). When the car is in AWD mode and the stick is in 1 and the throttle is fully open, going for max acceleration, solenoid C is almost completely de-energised. A low duty cycle. This seems to agree with Nomake's observations that a lower number indicates lockup (F50:R50) and a high number indicates power towards the front (F90:R10).
#667
Here's something else interesting from the service manual.
#669
I don't really understand the part where Trevor says, Quote:
#670
Why would the system not simply adjust to the prevailing conditions, while include what amounts to a time delay and an upper and lower threshold, so that a mean is established. This is normal within industrial process control, but the automotive world glorifies the process as a sort of learning thing. Both you and Nomake in your last posts, show that you have cottoned on to what is correctly involved outside of your black box. Well satisfied, you can relax a little, withdraw within and shut the lid again. Hooray!
#671
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 04-15-2008 at 04:17 PM. Reason: Edit added. |
#672
The quote from the service manual and the results of Nomake's experiment suggest to me that a high duty cycle is FWD and a low duty cycle is 50:50. Furthermore I was under the impression that "no FWD" (ie. RWD only) is an impossibility on a USDM tranmission. Please explain.
#673
I think it's a mistake in wording. To make things more simple, I believe it is this:
JDM: Normally Open. Closing [Energizing] the solenoid will activate the transfer clutch and result in 50/50 split. A failed solenoid will default to the 35/65 split. USDM: Normally Closed. Opening [Energizing] the solenoid will deactivate the transfer clutch and result in FWD. A failed solenoid will default to 50/50 split. This also makes sense since opening a solenoid decreases line pressure (deactivates clutch) whereas closing it increases line pressure (activates clutch). |
#674
Some multi-meters can actually. Fluke has made models that can for years, and some of the cheap chinese meters picked up this feature (lucky for us cheapskates).
http://www.mouser.com/search/Product...U97kdFdw%3d%3d For $30 it might be worth picking one up just to test your theories. Last edited by Calum; 04-15-2008 at 08:58 AM. |
#675
dang it, double post. Sorry!
