Old 09-02-2011, 12:05 AM
SVXx2's Avatar
SVXx2 SVXx2 is offline
Surging at Idle
OK, a new problem for me. When I start up the '92, it starts fine, but surges at idle. As soon as I depress the accelerator, all is well. It seems to run fine but continues to surge at idle when I get to the stop light, etc. I think it clears up after about 10 minutes, but not sure. I'll keep an eye on that. It normally idles at about 700, and the surge takes it to about 725-750. Very rhythmic. About 1 sec per surge up and down. Ideas welcome and appeciated.
Old 09-02-2011, 08:11 AM
httrdd httrdd is offline
Re: Surging at Idle
Mine does the same. I have to replace a cracked vac line in which has a temporary repair.
99 OBP LGT Eg33 swapped.
92 pearl LSL for parts.
Old 09-02-2011, 01:54 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Re: Surging at Idle
this happened to me and it was my O2 sensors
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 09-02-2011, 03:22 PM
Re: Surging at Idle
not to add more options but mine did this when i bought it and the tps was misadjusted
Old 09-02-2011, 03:27 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Surging at Idle
Sounds like an air or vacuum leak. Have you had the snorkle off of the TB lately? The rubber seal can get twisted when you reinstall it, causing an air leak.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-05-2011, 11:07 AM
Re: Surging at Idle
TPS...had that problem on my dad's SVX.
Old 09-05-2011, 11:33 AM
Subaru Alliance Subaru Alliance is offline
Re: Surging at Idle
just had a similar problem on my neighbors mazda, I unplugged the TPS and it instantly stopped but through out a CEL, I plugged it back in immediately started surging again and CEL went off. I replaced the TPS and it's good now.
2003 Baja Sport
1994 SVX LS
1992 SVX LSi parted out
