Old 03-22-2009, 09:58 PM
techy101's Avatar
techy101 techy101 is offline
A.L.I.C.E.
Send a message via AIM to techy101 Send a message via Yahoo to techy101
Re: Techy's engine pull progress thread
EDIT: Moved all of these questions to a technical thread.
It appears that that Trans. code is back. I'm not sure why it stopped for a while then came back... but oh well. Again, it's a Code 22 "Atmospheric Sensor"
Here's a video that was requested on my local forum.
ALICE: 2005 Forester XT (Ice Racing Machine)
River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment)
Old 03-23-2009, 05:56 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
wow, now that's different....it's like the engine is going "I won't let you go over 3k rpms!" The car is definitely in "limp home" mode. What year SVX do you have again? I've heard of non-SVX subies going into limp home mode when their egt sensor gets messed up. You might also want to check the MAF and harness for the MAF. Only the most serious of "codes" will cause the car to go into "limp home" mode.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-24-2009, 06:02 PM
teal one's Avatar
teal one teal one is offline
This is GREAT stuff!! Many thanks for taking the extra time to take pics and post your progress. This will surely be a huge help when I get ready to do mine!
Old 03-24-2009, 06:25 PM
any progress made on this techy? were you able to troubleshoot the source of the problem?
Old 03-25-2009, 05:23 PM
I am seeing a lackof communication to and from the ECU. The baro sensor is internal to the ECU and considering the tacho and reving issues... I can say there is def. a problem to be had w/ grounding somewhere. I'd start with the gnd on the back apss side of the intake manifold
Old 03-26-2009, 05:53 PM
techy101's Avatar
A.L.I.C.E.
I think it's fixed
I win the dumbass of the year award though...
I said I checked that ground location, which I did, but only visually. It looked nice and tight. If I had pulled my head out of my ass and actually tightened it I would have noticed that it was just a tiny bit loose. Tightened the bolt, pulled the neg battery cable to reset things, put it back on and she fired right up.
Lesson learned, trust the Toms *hangs head in humble shame*
It also explains the speedo error since that is the ground location for the speed sensor.
Here are a few pictures of things shined up a bit. There's a lot more detailing that can/will possibly be done, but for now:
Old 03-26-2009, 06:08 PM
I am just glad to hear that you got it resolved. Nothing is worse than the feeling that you total F'ed something up. It must be a big relief, and the engine looks great.
Old 03-26-2009, 06:23 PM
nice job. Glad all is better
Old 03-26-2009, 06:38 PM
techy101's Avatar
A.L.I.C.E.
I must offer my public apologies for not looking harder at that bolt.
Old 03-26-2009, 06:40 PM
techy101's Avatar
A.L.I.C.E.
I think this might just be the motor mounts, but when I'm sitting at idle I can feel (and barely hear) something making a very faint thump-thump-thump, it sounds like it's twice every revolution?
On a positive note, my cruise control is working again. I replaced the switch in the steering wheel so that may have done it, or something else I did. I didn't take the systematic approach to that, just replaced the switch while I was doing everything else.
The cruise went out a few months ago, and was not because of this engine pull.
Old 03-27-2009, 11:10 AM
How come no A/C?
Old 03-27-2009, 11:20 AM
techy101's Avatar
A.L.I.C.E.
Originally Posted by SVXMAN2001 View Post
How come no A/C?
It was broken when I got the car, seized compressor, and the box inside the cabin was filled with debris. So I just pulled it all.
Old 03-27-2009, 01:16 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Looks good. I would respray some black on your core support though, looks rusty.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 04-16-2009, 11:21 AM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
wow, awsome how to info!
i need to re-seal my engine...she leaves a mess at home and at wrk
how much did it cost again?
and how long did it take....or would it be better to have some else do it?
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 07-13-2009, 08:00 AM
alia176 alia176 is offline
VERY nice thread indeed, thanks for the picumentation (word?)
I know it's been a few months since the engine went back in but I'm about to start this project and had some questions, if I may.
- what is your garage ceiling height? I need to make sure that mine is tall enough to be able to pull the engine out inside the garage.
-did you have to do much work under the vehicle or did all work take place in the engine bay.
-did you eliminate the EGR system due to the broken exhaust manifold piece or was it for some other reason? Is the ECU not smart enough to know the deletion of the EGR, I'm assuming not, otherwise a CEL would be thrown.
-how easy was the access to the torque converter to fly wheel bolts? Where and how did you access this?
-were you able to use bulk hose from the local auto part store (1/8", 3/32", 3/16") or did you have to purchase metric hoses from oem?
-I assume you used WRX motor mounts?
-Do you recall which vendors you purchased your items from? Timing belt came from Ebay, how about hoses, motor mounts, etc?
My apologies if you mentioned these answers in your thread and I didn't see it or understand it.
Thanks.
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
