Old 03-18-2009, 09:19 PM
Re: Techy's engine pull progress thread
that is just one sexy engine!
Old 03-19-2009, 01:46 AM
techy101's Avatar
techy101 techy101 is offline
A.L.I.C.E.
Send a message via AIM to techy101 Send a message via Yahoo to techy101
More stuff from tonights work
Valve cover gaskets
Seals installed
Valve cover on
Starting to look like an engine again. Just much cleaner
Oil pan removed, prior to cleaning mating surface
After cleaning
Nasty old seal on the oil pan
ALICE: 2005 Forester XT (Ice Racing Machine)
River: 1992 SVX LS-l 125,000 # 0930 (getting fixed up at the moment)
Old 03-19-2009, 01:48 AM
techy101's Avatar
A.L.I.C.E.
Well crap!
I just remembered that I forgot to remove the bolt holding the intake cam gears together
Another "I feel like a dumbass" moment
At least I remembered now and not later.
Old 03-20-2009, 01:01 AM
techy101's Avatar
A.L.I.C.E.
More work done today. Not as much as I'd hoped, a friend lost her job so I spent a while with her. Friends trump car.
But I got the oil pan put back on, although I think I probably used too much RTV. Hopefully it won't be a problem.
Also removed my bolt from the intake cam gear from last night.
Then it was just putting things back together. Slow going, but I'm making progress. For anyone else doing this, label the hoses. There were a few that I labeled, but most I figured would make sense because of location. Not so much. It's making things take a lot longer.
I couldn't find a plug for the EGR hole in the exhaust manifold, so I finally just cut the pipe and had someone weld it shut.
Oh, and I installed the locking pin in the front passenger half shaft @ the diff. I have had some suspension noise ever since I got the car, and when we got it apart I noticed that that locking pin has been missing since I bought the car So not cool. It was a pain to get in, but hopefully it'll make things better.
Finally, tomorrow my ebay timing belt kit will be here.
Here are today's pictures:
The offending bolt:
Oil pan on:
Intake Manifold
My solution for the EGR line on the intake manifold side
I used high temp silicone to re-attach the little brackets that hold the coil pack wires on.
Starting to come together
My welded and re-installed EGR thing
And finally my new locking pin
Old 03-20-2009, 04:05 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Now would have been a good time to install some thermo spacers on the intake.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 03-20-2009, 05:04 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Im surprised you didn't paint the intake plenum since it was off, but the engine is coming along very nicely
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-20-2009, 08:22 PM
scottsvx's Avatar
scottsvx scottsvx is offline
f'n a cotton, f'n a...
Looks really good, nice work! I'm actually doing the exact same thing, but school's making it take about a thousand times longer I anticipated... Anyway I had a couple of questions:
1. I noticed the copper spray-a-gasket, is that really helpful and should it be applied to all gaskets or just the head gaskets?
2. As far as that egr hose off the exhaust manifold, what effect does just plugging the hole have?
3. And you haven't gotten there yet but like you were saying, I was thinking the hoses are going to be a pain. When i took the intake manifold off those egr hoses broke like twigs. So I guess the question is when you break hoses like that, can you just get a hose that has the same specs and cut it to length or do you have to get the oem hoses?
Old 03-20-2009, 10:36 PM
techy101's Avatar
A.L.I.C.E.
1. The copper gasket sealer was recommended to me by the folks over at the local dealer. I used it on the head gaskets and on the intake manifold gaskets, although I didn't take a picture of the intake manifold ones after they were sprayed.
2. I removed the whole EGR system, so to keep exhaust from filling everything up I needed to plug the hole. Don't want a big old exhaust leak in the engine bay!
3. For a few of the hoses (PCV, etc...) that are molded in very odd shapes I have gotten OEM, but for other stuff I just get lengths of hose from the local auto parts store.
Old 03-20-2009, 10:42 PM
kwren's Avatar
kwren kwren is offline
Originally Posted by techy101 View Post
Well crap!
Would be easy to forget
You are doing great and much help for all of us!!!
Keith
Old 03-20-2009, 10:45 PM
techy101's Avatar
A.L.I.C.E.
Today was a lot of cleaning, and waiting for the nice UPS lady to show up.
My eBay timing belt kit came in and I am very happy with the quality. It was purchased from The Import Experts on ebay (they also have a website). Since they have a brick and mortar store they have a phone number posted on their website. I was able to call and arrange expedited shipping. They were a pleasure to deal with and I would highly recommend them to anyone. (They show as shipping from Washington State)
I am having a hell of a time with the rear main seal. It took up most of my night so I finally gave up.
Here are the pictures:
Cleaner cross-member
Clean Power Steering Pump
Cleaned up PS and Alt. tension bracket. It was pure black when Is started
New idlers installed
Timing Belt on. The orange RTV is to help hold the rear cover in place since a few bolt locations were broken
Back together
Ready for a new rear-main seal (The little nicks that the flash brought out are only on the outside, the surfaces where the seal goes is perfectly smooth.
Old 03-20-2009, 10:59 PM
Don't put that engine in yet... Those mounts are shimmed WAY too far out. You need to take the washers out and measure 1/4" of them combined. Looks more like a 1/2" as they sit and you don't even have a full nut's worth of threads on the studs
tom
Old 03-20-2009, 11:00 PM
techy101's Avatar
A.L.I.C.E.
tom
The washers on each side measure in at exactly 1/4" on my tape.
Should it be 1/4" including the plate?
Old 03-20-2009, 11:04 PM
No the spacer should be that alone plus the stock plate
Old 03-20-2009, 11:06 PM
Sorry, looked at the pictures again. I was seeing the reflection of the washers off the bottom side of the mounts that made it look like you had twice the washers in there that you do... My bad
tom
techy101's Avatar
A.L.I.C.E.
Oooohhhh, I think what you're seeing is a reflection of the washer stack against the black paint. It's not at the best angle.
EDIT: Hah, we both just posted at exactly the same time.
