  #46
Old 12-04-2008, 06:48 AM
sicksubie's Avatar
Re: TURBOs!?
Originally Posted by Sanosuke View Post
Well thanks for the advice. I need to research more, plan better. I am going to get the car at my residence before I do anything anyway so that means driving it across the US. PA to AZ, some where like 2371 miles, 3815 km. W/e.
My research line goes;
Body work + fiberglassing + light weighting,
Power creation + Engine management,
Power to the floor + differentials + axle/ lug/ wheel options (can you put modern diffs like STi DCCD in SVX?),
Suspension + coil overs + all minor and major parts,
Brakes + rotors + that stuff,
Stickers + Lambo doors + large wings + sick nasty body kits! jk.... I might put vertical doors on it...
You can use any rear diff that you want from any other subaru basically... You will need a much more specific work list than that to prevent this project from ending in aggravation and failure.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 12-04-2008, 07:50 AM
longassname's Avatar
Just some dude.
Re: TURBOs!?
oooh you don't own an svx yet.....
Your list needs correction then. Typically when you buy an SVX the first several thousand dollars go to repairs you were unaware were needed.
Old 12-04-2008, 01:06 PM
Sanosuke's Avatar
Sanosuke Sanosuke is offline
Found a lost SVX
Re: TURBOs!?
Originally Posted by subbieatnz View Post
actually i wonder how many people check there compression on there svx
Stock before modifications?
:..Miharu..:(1994) Laguna Blue SVX 170k. MODs: Beat to shjt.
:..Fey..:2005 World Rally Blue Impreza WRX 80k and rising. MODs: Lowering springs, 22mm sway bars. SS brake lines.
Old 12-05-2008, 11:03 AM
sicksubie's Avatar
Re: TURBOs!?
Yes, as that is when it would be important to know....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-06-2008, 03:29 AM
Banned
Re: TURBOs!?
too true, too true!
my parents got mine for about 2500 more or less, then about 2K of repairs went in before they let me drive it for more than a spin around the block.
Old 12-06-2008, 03:31 AM
Banned
Re: TURBOs!?
A buddy of mine who's an STI owner brought up another turbo to me last night and I thought I'd run it buy you all and see if any of you had heard of it. It was a Borgwarner that he said was between a garret gt30 and a gt35 in size and such. Any thoughts??
subbieatnz's Avatar
Re: TURBOs!?
Stock. Ive never checked any of mine. I dont even think i could even get my compression tester in there with motor in place
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 12-06-2008, 08:30 AM
sicksubie's Avatar
Re: TURBOs!?
yeah you can... Most shops charge 100-125 to check the compression on a svx
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-06-2008, 08:31 AM
sicksubie's Avatar
Re: TURBOs!?
If you are putting it on a built eg33 than it would be a waste of money, but for a stock motor it should be decent....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-06-2008, 09:17 PM
Banned
Re: TURBOs!?
compared to doing a 35R on a non built motor? which would you prefer bobby?
Old 12-06-2008, 09:20 PM
sicksubie's Avatar
Re: TURBOs!?
I would do the Bogwarner rather than a full out 35R on a stock EG33....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 12-09-2008, 08:14 PM
svxfreq's Avatar
svxfreq svxfreq is offline
Re: TURBOs!?
Curious Question(sorry it's a bit off topic): But how do you check compression and can you do it yourself? What do you do just take out one sparkplug at a time and measure the pressure that the cylinder can create without ignition?
'97 Ebony Pearl SVX Lsi
Current Mods: K&N Filter,
-18x8" Konig Hotswaps with Nexen Tires
-Polyurethene swaybar bushings
-iRotor Drilled/Slotted zinc plated rotors, ceramic disc pads, stainless steel braided blue covered brake lines, powder coated calipers.
Soon - Custom Headers, Cold Air Intake, and Custom Magnaflow Exhaust
*New addition*2000 Volkswagon Golf TDi
(don't worry, it's my new winter beater, gives me more money in my pocket(less gas) and I can park my car for longer periods of time giving me time to work on it and less damage to the SVX from winter driving)
Old 12-09-2008, 08:21 PM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Re: TURBOs!?
Yes and yes.
Dustin
-Dustin
Old 12-12-2008, 12:57 PM
Sanosuke's Avatar
Found a lost SVX
Re: TURBOs!?
I do own it now, payed for and all. If I was going to bring my SVX to a shop an get an estimate they would tell me to get another one... All the repairs are going to be done by my hands and thats all body work. The engine runs great.
I don't have a pressure tester, and if I did I probably would test it to know its out of spec. But there are no serious problems with it so its not way out of whack. It doesn't burn oil and the idle is smooth. I will check it when I get the engine out before I tear it down for cleaning and measuring.
Turbos are cool, way cool.
Old 01-22-2009, 07:08 PM
cozykat's Avatar
cozykat cozykat is offline
Still rebuilding my block...
Alcyone Silver Contributor
Re: TURBOs!?
bump because I find this all interesting and I am about to build my motor.
Marisa
