Old 11-23-2005, 10:02 AM
OBI OBI is offline
EJ22 Turbo pistons
I want to build a turbo svx motor and the idea of fitting these pistons greatly appeal to me over forged custom pistons. As you all know There is no documented fact of this ever been done. I would like to change that. All I need to discover this possibility is a used svx piston in a standard bore B or C.
I have a 2.2 turbo shortblock ready to fit it into. If anyone knows where i can get this svx piston please let me know.
Old 11-23-2005, 04:04 PM
MidgeX
i doubt they are the same bore
Old 11-23-2005, 04:34 PM
They ARE the same bore and stroke....
the EG33 is basically a EJ22 with 2 more cylinders
Old 11-23-2005, 06:12 PM
OBI OBI is offline
I just paypaled tomsvx he's got the piston. Yes the bore and stroke are the same but if the rods are different it might not work. as soon as i get this piston i will be able to find out for sure. Ill post the results.
Old 11-24-2005, 10:20 AM
It will go out on Monday after the holiday weekend is over... sorry for the delay
Old 11-24-2005, 09:20 PM
OBI OBI is offline
Thanks Tom, Im in no hurry.
Old 11-29-2005, 11:52 PM
dieingSVX dieingSVX is offline
if you need anything else i have a stripped motor i can donate some parts.
92 LS-L been sitting for 6 years.
86 fiero gt, t-tops, 3800sc, headers, intercooler, p&p blower and lower intake, 3.0 pulley, 1.6RR's, double roller timing chain, xp cam, 130lb valve springs and hooisers :P
87 starion- currently rides on jackstands.
Old 11-30-2005, 01:05 AM
intelisevil's Avatar
<<<Alcyone
longassname is looking for some alternator brackets.
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 11-30-2005, 01:01 PM
OBI OBI is offline
Thanks guys. Im waiting for the piston Tomsvx sent me. if it dosent have the pin i will need it too. I already took the heads and pistons off the 2.2 block. So far I have been comparing specs from the ej22 manual and the svx manual. the piston diameters,bore diameters and clearances are identical but I cant compare the piston pin diameter since the svx notes i have are missing that data. The 2.2 pin diameter is 22.994 - 23.000 mm. Can anyone confirm this to be the size of the svx pin? There are other things to compare as well like the piston skirt length and conecting rod width and length and if the piston sticks out past the deck. I cant wait to get the piston so i can install it on the 2.2 block and answer all these questions.
Old 11-30-2005, 01:26 PM
I shipped the piston all the rings on it... the pin and the circlips that hold the pin in
Old 11-30-2005, 02:33 PM
no offense to lan, but i asked him for an idea or something a while back and i don't know remember what he said i just remember it being a dick comment. so i'll keep my altenator bracket.
Old 12-01-2005, 12:52 PM
OBI OBI is offline
Guess what fellas, The pistons are a direct fit. were in buisness. I installed the svx piston in the ej22t block and it fit like a glove the piston protrudes a tiny bit over the deck but the turbo piston is flush at the deck that means that the turbo piston will not protrude over the deck in the 3.3.
Yeah Baby!
If your cylinders are good all you need is a light hone, the turbo pistons, rings and pins an you got lower compression. I would like to calculate what the compression will be with the 3.3 heads. help me figure this out guys. I can cc my ej22t heads. Can the commpresion be figured out if we had both the 3.3 and 2.2 CC volumes. The ej22t has 8.0:1 compression. lets say the ej33's CC has 5 more cc's than the 2.2 heads what would the commpression be then (obviously lower)? Lets figure this thing out.
Later,
Obi
EG33 Turbo Porsche 914
Old 12-01-2005, 12:57 PM
OBI OBI is offline
I forgot to say the turbo pistons are ceramic coated from the factory too
Old 12-01-2005, 01:00 PM
Good to hear that OBI, do they fit also on the rods?
Old 12-01-2005, 01:05 PM
ok ok, before i get to excited, they way i read it i'm taking you checked the rods to? i'm just trying to be sure it looks like you have too. if you did you are the man and i'm very greatful to you for doing something nobody has done yet! if you ever need something that i can help you with don't be afraid to ask...
alright here's what's next. Group buy on pistons!!!!
