Seeking help from those who might have insights ...
I am having a fair bit of work done on my '92 SVX by a mecahnic who has worked on the car on and off for the past 10 years. he knows the car well and is a smart guy. He's come across a stubborn problem (described below).
Might anyone have some insights to offer ? I have replaced the timing belt, water pump, tensioner and idlers on a 1992 Subaru SVX. It is a Canadian car. Two cam plugs on the front of the engine for the upper cams have also been replaced. In addition, a new ignition cylinder, housing and switch with accompanying OEM harness has been installed. After completing this work the car performed very well. However, after a few more engine starts/ offs the engine would sometimes ( intermittently not start). The engine would crank over but not start. Thinking it could be the new ignition system I reinstalled the worn ignition system. Unfortunately, the engine would not start this way as well. The new ignition system looks identical to the original worn system. Upon cranking the engine there is no fuel injector pulse and no check engine icon display with the ignition in the " on " position. The grounds at visible junctions have been cleaned. Cam sensors at the front of the engine show acceptable 2.4 - 2.5 ohms per side. On occasion I hear relays clicking on and off despite no ignition being placed in the "on" position. Any insights would be appreciated.
92 SVX, Ebony Mica 186,000 kms 92 Mercedes Benz 300CE, Arctic White 187,000 kms |
Re: Seeking help from those who might have insights ...
sounds like a wiring problem to me. if you get no ce light then the pcm is likely not getting power or ground on a particular circuit. i would pull it down and pin out the power and grounds when the problem is happening. if all powers and grounds are good check for 5v reference voltage at the tps. if no reference voltage check for 5v at the computer. if no 5v at the computer pcm is most likely bad. pcm failure is rare in any car so i would bet on loss of power or ground to the pcm.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
Thank you.
Check your fuses and links as well. My ol Xt-6 had about the same issues once, intermittent no start with no cel when the ignition was on. Ended up being the fusable link had blown, but not taken out the covering. The wrap would hold it together 90% of the time, but every so often it wouldn't go.
~Phil 94 Front Wheel Magic SVX 89 XT-6 EZ30 6 speed 79 Subaru FE 97 Impreza sport flintstone edition 78 BRAT! 76 Alfa Romero GTV |
