svx sounds diesel
when i listen under the car near the belts and oil pan there is a loud knocking and it almost sounds like its diesel.... is this normal??
No its not normal.
Down to none |
Re: svx sounds diesel
yes i know, an old thread bump....
i was looking to see if anyone else had a svx that sounded like a diesel when it was running. keep in mind this is my first svx but not my first boxer engine (H4 or H6) so i know what they typically sound like. comparing it to the videos on youtube i cant what is causing mine to sound as loud as it does. here are some of the ones i found to compare Idle video 1 idle video 2 i plan on taking a video of mine and posting it up here
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
Mine sounds a little dieslish now. Mainly due to neglect, hope it will be creamy smooth again when the engine is pulled and overhauled.
I got my girl, I got my glass, I got my car and I'm ready to f... |
the loud deep thumping is rod bearings that are quite worn from neglect slamming about...
I agree with Jake that its rod bearings but I also think its an oiling problem because my car only does it sometimes.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
