Old 07-30-2003, 07:56 PM
michael's Avatar
michael michael is offline
What Potholes ???
Talking resetting ecu
Hi everone, I got some new pics in my locker, if your bored, any suggestions welcome. I tried to reset my computer with no luck, Iplugged both blue wires into the upper left 2 plugs and started the car. I tried disconnecting the battery overnight, I tried touching the disconnected terminals together, The codes are 32 & 34 I put in a new 02 which should have cured 32. Got any other ideas.
Wanted: Steering Wheel
Old 07-31-2003, 05:02 AM
svx_commuter's Avatar
Is your CEL on all the time? It might be a bad wire or connector going to the O2. The new O2 did not fix the wire. Resetting will clear codes when the problem goes away. Do you drive it alot? Maybe someone else will know for sure about damage to the CAT when the O2 is OOS(out of service)
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
