Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 12-24-2004, 09:41 PM
question answered thank you.
Old 12-25-2004, 10:24 AM
Wreckless
It seems that you all are assuming the EJ22 and the EG33 have identical chamber volume on the cylinder heads. Is this a given or has this just not been adressed? This would be just as critical in determining compression ratio as the pistons themselves.
I vaguely recall my friend's (SVXtasy) own research on this matter to have discovered that fitting EJ22T pistons into an EG33 was both possible and would have netted a compression ratio of 9.0:1 or thereabouts, citing the cylinder head design differences between the two motors.
Old 12-25-2004, 04:37 PM
oab_au oab_au is offline
No we arn't assuming the two chambers are the same. As I said a few post ago, the 3.3 could have a bigger combustion chamber, as the 3.3 piston has a raised lump on it, and according to Wayne, the 2.2 engines have a resessed cut out in them. May be the valve sizes could be different. Thats why I would like to see some pics of the 2.2 and 2.2 T pistons.
We do know the volume of the cutout in the top of the two pistons,( 2.2=14cc, 2.2T=28cc) and that difference alone will drop the ratio by 1.4:1 at least. If the 3.3 chamber is bigger, than the 2.2s 40cc. then the drop will be more than this.
What were the " cylinder head design differences between the two motors"?
One Arm Bloke.
Tell it like it is!
Old 12-25-2004, 05:42 PM
lee lee is offline
Harvey, et al,
here's one site that addresses combustion chamber volume, etc.
http://wac.addr.com/auto/obs/turbo/ejcalcs.html
there are some pics of cylinder heads here (although after a port & polish job.
http://www.xcceleration.com/engine-p...ceengines.html
let me know if this gives you enough info.
Old 12-26-2004, 12:00 PM
Wreckless
Originally posted by oab_au
..What were the " cylinder head design differences between the two motors"?...
I honestly don't know, I'm a Toyota guy and I'm shooting from the hip w/hearsay because a friend I trust (SVXtasy) told me about it following his own research for dropping compression in his turbo'd SVX.
Old 12-26-2004, 04:22 PM
I honestly don't know, I'm a Toyota guy and I'm shooting from the hip .
Yes your car collection says that, No need to apoligise, we all make mistakes. May be a real car, like a SVX next time.
Sorry, could not resist.
Untill a 3.3 combustion chamber is cced we woun't have the full story, but I think we are on the right track.
One Arm Bloke.
Tell it like it is!
Old 12-26-2004, 11:58 PM
I guess the pistons thing is taking a lot of debate... one question though, ARE THEY THE SAME DIMENSION AS THE LEGACY'S ??
I am asking it straighforward because some say it is not, others say it is !!! I just need a yes or no answer !!
one other thing, what should be done with the fuel mapping, valves timing,etc... in order to fit a turbo?? what is the cheapest way? in conclusion to this debate..
Old 12-27-2004, 01:54 AM
THAWA
why do you need someone to say yes a hundred times?
Old 12-27-2004, 02:16 AM
when you see a thread full of yes, no, yes, no, yes, no, yes, no...... one becomes ..... it's not I need a yes hundred times but rather if all agree on something....
thank you Thawa for making me feel very stupid !!!
Old 12-27-2004, 02:32 AM
THAWA
It's what I do.
Old 12-27-2004, 04:02 AM
It's what I do.
LOOOOOOOOOL !! how much you make out of it by hour??? U're allright buddy ...
Now serious, what about fuel mapping and valves timing...? (in conclusion)
Old 12-27-2004, 05:11 AM
SEA Sleeper
This was attached less than a page ago
http://www.subaru-svx.net/forum/atta...&postid=272148
Not to try to speak for anyone but I think what THAWA was indirectly trying to say to/ ask you is why you don't read the threads more thoroughly.
are you sure??? because I heard it was rather 9.999..... not 9.69. If this is the case, I would bore the chamber to put the 9.96 cm pistons...
This question was also previously answered earlier in this thread. In more than one place..
Really, your enthusiasm is great, but read the WHOLE thread before you start asking so many questions.
Now fuel mapping and valve timing... I suggest you start another thread related to that specific subject.
Only untill we know the geometry and volume of the EJ22 & EG33 heads will we be able to proceed w/ any certainty.
Old 12-27-2004, 06:00 AM
Man!!! i am getting hit by all the guys over here. Well seasleeper, I read the whole thread very carefully, some say the pistons fit, other are saying they do not... some say that SVX has ACTUALLY 9.99cm bore pistons, others are saying they are 9.69cm.... really speaking I am lost... I know I asked the same questions again and again but in each time the guys say, the pistons won't fit for X reason other say they will fit for Y reason... there are many opinions concerning the issue!!!!
Old 12-27-2004, 04:41 PM
OK Danny this is the state of play.
The Legacy has the same bore and stroke as the SVX.
The pistons will fit the SVX.
The different 2.2 lt pistons have different cutouts in the top that change the compression ratio. If the Legacy 2.2 Turbo pistons are fitted into the SVX the compression ratio will drop enough to turbo or supercharge it. Exactly how much the ratio will drop is not clear at the moment, but it will be at least 8.6:1, may be more.
One Arm Bloke.
Tell it like it is!
Old 12-27-2004, 11:23 PM
SUMMARIZING SO FAR BORE AND SLEEVE
