Old 04-06-2005, 01:08 PM
nysvx10 nysvx10 is offline
Exhaust Problem Help
In need of ideas/fixes for my exhaust.
Problem: New York salt has slowly killed my exhaust and now it is deafening....The flanges on the pipe coming down from headers (containing cats and O2 sensors) have rusted off. The connection between these pipes and the primary cat is pretty much gone.
Solution: No idea. Do not want to spend the $300+ each to buy new pipes. Has anyone else had this same problem and if so how was it fixed(pictures would be great)Any ideas or alternative fixes out there????
Please help
Caleb
Old 04-06-2005, 01:50 PM
How about installing the high flow 1-1 cat in place of the current 2-1 cat. Who has done this. Was it as easy as chopping the pipe behind the flanges and welding on a premade "Y" adapter on and then just weld the new cat to that?
Old 04-06-2005, 03:23 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
A decent exhaust shop can remove the pre-cats and make pipes to replace them. You'll need to replace the main cat with a universal that is rated to replace all three to stay Federally legal. A 2-1 cat will make it easier for the exhaust shop.
Old 04-07-2005, 01:16 PM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
That is amazing! i have the exact same exhaust leak ....at first I thought it was just the donut gasket at the flange, but no -the flange is starting to disconnect itself from the pipe.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 04-20-2005, 07:57 PM
Any luck rmjjensen, or anyone else for that matter???
