Old 11-24-2006, 10:33 PM
Originally Posted by TomsSVX
mine does it too... The car is 15 years old man... Give those transfer clutches a little slack... with new ones they would engage right away... It is not a problem if they don't... it is not going to kill you... Harvey, it is not that strict and you know that
As I read it, Tom is saying and others confirm, that this as a cause of front diff. damage, is not a proven issue.
Old 11-25-2006, 06:52 AM
dcarrb dcarrb is offline
mine does it too... The car is 15 years old man... Give those transfer clutches a little slack... with new ones they would engage right away... It is not a problem if they don't... it is not going to kill you... Tom
Again, I'm not smokin' the fronts and would probably never have paid this any mind if I didn't have the two cars to compare. I'd just like to gain a better understanding of what's "normal" (as my only pre-SVX AWD experience was with 5-speed manuals), and I appreciate everyone's input.
dcb
Old 11-25-2006, 11:44 AM
I wish I had AWD. ):
My fronts spin like crazy. I wonder if my front dif hasn't cracked open yet because there is no power going back?
Old 11-25-2006, 10:38 PM
Ok, I have seen the best and worst front differentials... The ebst is when... well all the gears have next to no wear and the bearings have always been properly lubricated... The worst can come in a couple different ways
First front diff explosion I dealt with was on my FWD 94... the 1st SVX I ever had and worked on... The diff seals on the trans went to crap before O bought the car and as soon as I bought it I check and changed all the fluids... The moaning front diff made sense and not 10k later the front diff bit the dust for good. When the gears in the front diff are worn to be razor like edges it is because A) the gears were not set properly during installation B) there was no oil and the bearing went to crap and lost the placement of the gears and ground them to dust
Second was the cracked case... Seems to be that some of the aluminum diff cases have weak points in their casting and the torque of the EG33 can break them and cause a crack which can lead to gear misalignment or just total case failure in which it just breaks
third is when Harvey is leading to.. When one wheels spins faster than the other... This will lead to excessive spider gear wear in which the carrier (holds the ring gear) case gets chewed up and the spider gears begin to get toasted... This is when someone decides to leave their FWD fuse in and do burnouts or FWD models just do burnouts... Without LSD the carrier will allow all the power and torque to go to one wheel.
The transfer clutches on older cars get soft and slow to react... This means, the solenoid and transfer valve are all working properly but the clutches slip a little before full engagement. This means, there is no slamming of the driveline just a smooth kick from the rear wheels, this for sure will not shere the transfer drum off. Binding will do this or like LAN experienced with 12psi of boost, pure power will do this too...
I hope this clears up and discrepency with the AWD slow to react
BTW you should all switch to 5mt's... no more of that 90/10 torque split
