Old 07-24-2009, 08:29 PM
Trevor's Avatar
Trevor Trevor is offline
Transmission Pressure Gauge
I have in mind permanently fitting a pressure gauge which I have on hand, as a means of constantly monitoring line pressure.
A plug is provided in the transmission casing for this purpose and I hope someone will be able to advise the thread and size involved. If need be, I can I hope source a plug from a dumped transmission and modify this to work as a connection. However it would be nice to be able to purchase the correct item from a brass fitting supplier.
It will be obvious that I do not wish to purchase the Subaru test part from a dealer, my wallet is not bulging.
Another point requiring an expert opinion, is the restrictor hole in the gauge I have, which is mainly intended for use with gas. The hole damps the movement of the pointer. When used with transmission fluid without an air lock adjacent to the gauge, the damping may prove excessive for my application and the existing hole may be best enlarged. What do those with hydraulic experience advise?
Special thanks in anticipation, Trevor.
Trevor, New Zealand.
Old 07-25-2009, 11:25 AM
NiftySVX NiftySVX is offline
Re: Transmission Pressure Gauge
M 10 is the plug size on the pump, I have one set up on my car but I took it off for fear of line failure and spraying 176 degree atf in my interior at 275 psi.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 07-25-2009, 06:15 PM
Trevor's Avatar
Thanks a lot. I will be careful with the installation.
I was under the impression that you had monitored the pressure after the C solenoid. However you may have done this in addition to the overall line pressure. If so where did you connect for the after C pressure measurement. As you have reported this is certainly interesting to observe. I happen to have another gauge which would be suitable.
Cheers, Trevor.
