Snake oil or not
Post what you think and find out
Snake oil= just a product that is useless and is hyped up So has any one tried. Zmax engine conditioner ? Snake oil or not? |
Re: Snake oil or not
I don't particularly like this stuff, but Carroll Shelbysays he does.
"”I’ve built over 100 different kinds of cars… Shelby Cobra, the most replicated car in automotive history, over 20,000 Shelby Mustangs, the Viper… At 77, I wanted to see if I could build another good automobile like the Cobra. I call the car the Series One. We’re putting zMAX in each and every one that leaves the factory. It penetrates the metal, decreases the friction, cleans the carbon residue out of the engine. Therefore it gives you a more efficient engine and a lot more durability. I’ve got my reputation to protect and I wouldn’t recommend zMAX unless I knew it worked.” He probably mixes it with his morning prune juice Personally, I'm sticking with Lubegard BioTech Engine Protectant. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-01-2012 at 09:52 AM. |
i use it (or similar equivalent) in my '56 plymouth. i don't believe the hp or clean engine claims that they claim for new cars but it does help to protect engines with flat tappet lifters that were meant for different oil. as the new oils increase in grade the amount of additives is reduced. this can quickly wipe out the cam in a car that was meant for dirty oil and leaded fuel. bottom line: if your car was made before hydraulic roller lifters were used you need it, if not your wasting your money.
It is similar to and aviation additive that has been used for years to improve wear. There are conflicting reports out there on whether it makes a big difference. There isn't as big of a user base as, say, Lubegard to Auto-RX. It is most similar to Lubegard. It probably is a decent product but too little is known about it to justify the cost.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
I'm curious as to what makes you think this isn't snake oil. Not trying to start anything....like I said I'm curious
Matt 15 OBW premium w/eyesight A picture of an SVX in the garage |
You can articulate this much better. I am using this for a particular reason, that can't be addressed by M1 alone. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-01-2012 at 01:50 PM. |
Pick a Lubegard product, read their website for more information about it and then do a search on it on the BITOG website and read the stuff people post there. It will take a lot of time but you will get a good feel for their products. If you do this for enough different oils and additives you will also start to get a feel for which posters over there are the true experts and which ones are just part of the "I use it and it works great" crowd...also known as "opinions are like ***holes, everyone has one" crowd. For most people who drive their car daily, maintain it properly and don't abuse it, the vast majority of these products are unnecessary. But there are some special cases and people who let their cars sit for long periods between drives is one of them. And there are products out there that help. Lubegard and Zmax are a couple of examples. And some oils are better than others too. If you are rich, Redline's high Moly content would surely help. Again, you can find information as to why on the BITOG web site. And then you have cases where, maybe, the car's maintenance hasn't been so great and there is a problem or a loss of performance as a result. Some products are indeed just a bandaid. But some can really help and provide a long-term fix or improvement. Lubegard's tranny additives are a great example. Got a binding center diff on your AT? You might want to drain that old fluid and replace with fresh Subie fluid plus some Lubegard. If you didn't completely destroy the diff by driving with it that way for too long, you might be able to remedy the situation. I had binding on an '07 Outback with about 100K miles on it. I tried the Lubegard and the binding went away almost immediately and the tranny was operating perfectly when I sold it 6 years later with another 60K miles on it. Auto-Rx has been shown to work great on gunked up engines which were run in all sorts of abusive situations or on really crappy gas. Now, trying to "fix" a leaky radiator or head gasket with a leak fix is a different story.
