Old 12-13-2011, 12:42 PM
SubaruJawn's Avatar
SubaruJawn SubaruJawn is offline
got my SVX 12-8-11
Re: Vexine: 1992 SVX
she does pull to the left hard, so i think she may need alignment tire pressure matched by the sheetz pump.
no prob subeman, just didnt think if it.
i want to make sure Vexine is a good safe car, like i do scubert.
Old 12-13-2011, 10:40 PM
steamer99's Avatar
steamer99 steamer99 is offline
My local NAPA had the end links for approx. the same price as the e-bay ones, but they sell them individually ($20.00 each). Full details in my post on the other forum
current stable, subject to change without notice:
1995 Red SVX, 4.44 & Quick Change
2014 Nissan Titan S 4X4
1992 Teal SVX parts car
Old 12-14-2011, 12:58 PM
SubaruJawn's Avatar
got my SVX 12-8-11
seen your post on the other svx forum.
my local napa can get them i think both for $39.18 can get them next day if ordered by 1pm
cheaper than Ebay.
Napa Advantages:
cheaper
no shipping charges
get them faster
get to drive my svx to pick them up
Napa ones treating you good ?
Old 12-14-2011, 01:30 PM
+1 for napa
if you ever need to return it you will very happy you didn't use ebay
Old 12-14-2011, 01:45 PM
SubaruJawn's Avatar
got my SVX 12-8-11
Originally Posted by 92snowmachine View Post
+1 for napa
your right, this has happened to me already.
bought rear shocks for my XT6 and ended up being wrong, i still have the wrong set i bought from Ebay.
Old 12-14-2011, 08:31 PM
Well that is not too bad . Is it a big job to replace them without a lift.
Old 12-15-2011, 06:03 AM
SubaruJawn's Avatar
got my SVX 12-8-11
i have a lift
Old 12-15-2011, 06:15 AM
steamer99's Avatar
Not too bad, I did it by jacking up 1 side and putting it on a jack-stand, The hardest part was getting the nuts off. I had to zip-cut one of them since I rounded it off It really is as simple as:
1) jack up the car (and support it safely)
2) remove wheel
3) remove 2 nuts (the hardest part as they are probably rusted on) and take old one out
4) put the new one in, tighten 2 nuts
5) put wheel back on
6) lower the car
7) repeat on other side.
Old 12-15-2011, 06:29 AM
SubaruJawn's Avatar
got my SVX 12-8-11
2) remove wheel
6) lower the car
sounds easy, i had the driver side off when i checked the brakes for inspection, they passed.
in my case is will be
(minor alterations)
1) drive svx onto lift
7) No Repeat for jacking
Lift is awesome except when you do trans jobs, its an old-school 1 cylinder.
lift.
Old 12-15-2011, 09:32 AM
Green1995SVX's Avatar
lift.
Do you have to worry about environmental concerns with those? I've heard that it's pretty common for the to leak hydraulic fluid into the surrounding ground. I was looking to buy an old Dodge dealership a few years ago, but passed because it had originally had these types of lifts, and the seller couldnt provide a clean environmental study.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 12-15-2011, 12:27 PM
SubaruJawn's Avatar
got my SVX 12-8-11
it leaks fluid around the cylinder. as for environment stuff i have no idea we just use it.
here is pic of scubert on it.
video is really old.
Old 12-15-2011, 12:55 PM
i have a center post lift at the shop i'm at now. it's been in the ground for nearly fifty years and never lost any fluid. the newer ones tend to use mineral based oils in case it leaks. when people talk about them leaking it is usually from one cylinder to the other as in they leak down. if you leave a heavy car on it overnight it might not be as high as when you left it.
Old 12-15-2011, 07:38 PM
SubaruJawn's Avatar
got my SVX 12-8-11
bought trans cooler for vexine
gonna order the swaybar links tomorrow.
whats left will be saved for other ods and ends.
Old 12-15-2011, 07:55 PM
Harbor freight sells some nice lifts in the $2,500 to $3,000 range thinking about getting one.
Old 12-15-2011, 08:38 PM
in that price range you can buy a name brand lift like a bendpak or a rotary if you can find a good deal. i am currently pricing lifts myself and would never walk under a car on a harbor freight lift.
