Old 07-02-2001, 07:42 AM
LordLobo
Altnernate Transmission List
I noted a different thread where someone said they replaced their SVX tranny with a low-milage one from a wrecked outback for the fantastic price of $800. Of course, this guy did the work himself. Now, I have a friend who's pretty good with cars and has offered to help me replace mine, and the prospect of an $800 fix is very nice. [Note: list of pitfalls in the do-it-yourself tranny swap will be a different subject]
The question is, what other model's transmissions are compatable with the 92 SVX LSi's?
Old 07-02-2001, 11:51 AM
KEVINL
That was me. Just about any AWD tranny will work the newer ones are stronger but you have to take gear ratio into consideration Try to find 3.700 or 3.900 gear ratio and swap out the rear diffs
You may need a Tranny with a Electronic controlled Speedo the outback was but I think older legacys still used a Speedo cable
Old 07-03-2001, 10:53 PM
svxpert svxpert is offline
Question Tranny
So if you replaced the SVX tranny with one from an outback how is yours the only rear wheel drive svx?
Old 07-04-2001, 12:05 AM
KEVINL
Because the outback has very low gears I am able to use the stock rear diff with rear wheel drive
Old 07-04-2001, 09:28 PM
RWD
I think I lost you. What happend to the front diff and axels that came with the outback tranny?
Old 07-05-2001, 08:48 AM
Wink Electronic controled speedo
The unit that changes it to electronic signal mounts to the cable hookup on the tranny then the speedo cable hook into it(Yes my 92 SVX has a cable and electronic speed sensor. I believe the electronic unit is for the cruise control).
Another thing to remember in doing a swap is that you have to use the original torque converter(have it rebuilt about $200) as the SVX has a unique flywheel the won't bolt up to any other torque conv.
I'm running a Legacy Tranny in mine right now, I swapped in the original front diff. and now a front axle bearing is going out. hence my new project of putting in a manual in its place, which will eliminate all the automatic problems.....hmmmm now I'll just have to worry aout replacing the clutch instead of the tranny
The Legacy Tranny(other than the torque conv.) was a direct bolt in swap, but as allready suggested, use the Legacy diff's(front and rear) and it'll be less hassle.
Hope this has been helpful
Old 07-05-2001, 03:05 PM
KEVINL
then why do I have the outback torque convertor bolted to my SVX's flex plate
Old 07-05-2001, 06:09 PM
huck369
did you get my last e-mail with the postage price?
Old 07-06-2001, 05:42 AM
Question Torque Conv.
What year is your SVX, and what year Outback tranny are you using? My SVX is a 92 as is the Legacy Tranny I've got in it, on mine there was a BIG difference in the size of the T.C. as the SVXes was physically larger, maybe the Outback's have the heavier duty T.C. like the SVX, I don't know, haven't been down that road I could have used the flex plate off the Legacy, but I didn't have it.
And to SVXpert,
I did get your reply, now I've got to wait for my finances to loosen up and I'll get you a money order, e-mail me at whuck369@gte.net
with your mailing address
Old 07-06-2001, 07:46 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Torque Conv.
And to SVXpert,
When my rebuilder replaced the Legacy transmission that someone had placed in my SVX, it was necessary for them to also replace the flywheel. The folks who'd replaced the transmission had also replaced the flywheel so's the Legacy tranny would bolt up. So, as Huck said, unless the Outback has an "upgraded" TC, it shouldn't bolt up . . . unless, of course, someone had already had a Legacy trans in your car.
Randy Johnson
Mike Davis -- at Reading VI
