Timing jump?
So I changed the water pump the other day. All was good after. But then it started running badly. It runs relatively smooth but when driving there is no power and there's more of a drone sound in the exhaust. So I'm thinking it jumped timing or bad spark plugs. Any suggestions?
#1 1994 Ls ebony parts car-rip #2 1994 L laguna blue - sold #3 1992 Lsi pearl white - sold #4 1992 Lsi pearl white -Ate two engines - Rip #5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree #6 1992 Lsi custom orange parts car #7 1992 Lsi green 4.44 swap. Currently for sale #8 1992 Lsi custom pearl white. Project car... sold #9 1992 Teal 4.44 swapped... sold #10 1995 Laguna Blue. Sti 19 wheels, #11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂 |
Re: Timing jump?
1st rule. Go back to the last thing you did.... My guess is the timing is off a tooth. How does it sound when it starts...
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
Re: Timing jump?
Timing. Make sure you preload the tensioner. You may and should consider a new timing belt if you didn't replace with new.
Re: Timing jump?
Yeah I will change the belt eventually just been broke and the water pump wasn't cheep
Re: Timing jump?
Kinda gurgles on start up and takes a few sec longer to start
Re: Timing jump?
You can get a good timing belt kit on ebay for less than $150, including all the idlers.
http://www.ebay.com/itm/SUBARU-SVX-3...875017&vxp=mtr
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Re: Timing jump?
Sounds like timing belt is off a tooth. Must first mark timing belt cogs,crank and both cam pulleys with chalk or grease pencil and then re check and re check again by counting teeth on both sides of center crank. 53 teeth each side if I remember correctly.good luck with it.
