Old 10-08-2012, 09:33 PM
AlcyoneSVX's Avatar
Alcyone Silver Contributor
JDM Factory OEM HIDs
A few months ago I bought these headlights. They claim to be OEM HIDs from Japan. I didn't know they existed. They look genuine to me. Has anyone else ever heard of these?
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 10-08-2012, 10:46 PM
Re: JDM Factory OEM HIDs
No I don't think so. They look like normal JDM lights with a HID kit fitted.
The second Pict, the one on right, you can see where the standard wiring goes in the side of the cover, and the kit wiring in the back.
Old 10-09-2012, 01:16 AM
AlcyoneSVX's Avatar
Hey Harvey!
I went and looked at the backs of the headlights again. They don't look like they're aftermarket. The back caps that house the bulbs have two wires coming from the bottom edge that go to the main connector, same as the regular JDM, UK (which I also have), etc.. But then there's three rubber boots in the flat, rear part of the cap. Two small ones with one wire coming out of them and one larger one in the middle with two wires coming out of it. These wires, outside of the cap, all have separate connectors that connect to the wiring for the ballasts. Also, Sun Powerview is approved as OEM equipment in Japan. Could it be that Subaru used these HIDs in the SVX towards the end of it's production?
The photos I posted were from the advert. I'll take some other photos myself and perhaps get a better view.
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 10-09-2012, 01:28 AM
First known use of HIDs on cars was 1991, so it's possible.
http://en.wikipedia.org/wiki/Headlamp#HID_.28xenon.29
Old 10-09-2012, 05:09 AM
Darren's Avatar
Darren Darren is offline
That is a universal kit which has been fitted after market
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan.
Nissan R34 Skyline Stagea
91 Lotus Elan SE Turbo
1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new
You can tell the men from the boys from the speed of their toys.
Old 10-10-2012, 09:45 PM
Green1995SVX's Avatar
If you post a picture of the back of the projector itself, that will be the giveaway. If it has a D2S style bulb fitting, then it's OE. If it's just a standard H series type bulb, it's aftermarket.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 10-11-2012, 03:46 AM
Darren's Avatar
Japan uses H1 bulbs.
I have had one of my suppliers in Japan ask about HID's for the Alcyone while sorting some other parts for me and nothing is listed as a spare part or ever being an option.
I have never come across one in Japan with factory HID's in 14 years of business importing cars and parts.
The kit in the picture is an after market off the shelf item widely sold in Japan.
It is a very good kit though and the company are OEM approved for replacement parts so it's as near factory as can be I guess.
Old 10-11-2012, 04:56 PM
AlcyoneSVX's Avatar
Yeah, they're H1 fittings. Oh well, at least look like they're OEM. And they should be brighter than the H1 bulbs. I also found 21w super whites for the running/parking lights!
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 10-11-2012, 09:51 PM
Don't forget, since the headlights are setup for RHD cars, the beam pattern is backwards. You'll blind oncoming cars if you use these.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 10-14-2012, 01:39 AM
AlcyoneSVX's Avatar
I'll just point the beams down a little, like I did when I had my UK lights on.
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 10-14-2012, 02:02 AM
**Ewie**'s Avatar
**Ewie** **Ewie** is offline
Aussie in enemy territory
May not be as easy as that since the RHD version is designed to throw some light toward the road shoulder which is to the left. LHD version would throw to the right....
In short; you're throwing light at oncoming traffic. Lowering the beam may not be an issue in built-up areas but could limit your visibility on dark roads.
My ten cents.
Old 10-14-2012, 02:15 AM
AlcyoneSVX's Avatar
Well, I could go with my original plan, which is to disassemble the UK lights and install the US projectors, and use the HIDs from the JDM set.
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 10-14-2012, 02:26 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Take plenty of photos when u do the write-up
