Old 10-17-2007, 06:17 AM
cycleman60 cycleman60 is offline
Question key locks in ignition
I have a '95 SVX - original owner with 98K miles. Twice now the key would lock in the ignition so I could not shut off the car and take the key out. Luckily I kept it running in the parking lot and went straight home. Had to unhook the battery and stall it out to stop engine. I took the ignition assembly out and took to a dealer. He fiddled with the key and said "maybe" the soilonoid (sp!) was bad. I took the key assembly apart, sprayed a little silicone spray in it. Worked for a month or so and yesterday it did it again. I also notice at times when I turn the key to start it, it starts but the key does not go all the way back - the car runs but the accessories (radio, ac, fan etc.) do not work. I push in on the key and wiggel it and it goes back into place so everything works. Anyone have suggestions on what I need to replace? The dealer was NO help. Is the problem in the ignition assembly (where the key goes in) or some silonoid(sp!) somewhere that needs to be replaced. Oh, one other thing - every since I put it back together the buzzer rings whenever the door is opened, whether the key is in or not. Since I left the dash padding off, if I slide the one assembly at the top of the ignition in, the buzzer stops, but it doesn't go back by itself to stop buzzing.
Old 10-17-2007, 09:09 AM
99% sure it is the ignition assembly to me... Try buying a used one with its key off ebay, replace it yourslef and see if you still have that problem...
(if I were you I would also buy the whole car set along with it )
Old 10-17-2007, 09:15 AM
It sounds like the barrel of your ignition switch is worn, and/or the interlock is not lined up properly.
You can actually buy an ignition lock set from the likes of subaruparts.com. Not too expensive I would think.
However, you first need to read up about the interlock connection. This is the solenoid which does not let you start the car while the shifter is engaged in gear. This can come out of position, and either hold the key in place or possibly prevent the car from starting.
Your ignition barrel is held in position by two shear bolts[for security] from underneath. If this comes loose, it creates these kinds of problems with the solenoid. Is it loose? If you catch the key while in the ignition, can you move the whole lock?
If so these bolts have come loose. You would need to tighten this up before you go chasing the solenoids.
Hope this helps.
Old 10-17-2007, 09:16 AM
First Post!!
And BTW, you are very welcome to the Network!!
Old 10-17-2007, 02:19 PM
Bolts were tight. Nothing on Ebay. Found two items and don't know the difference between them. "Ignition lock cylinder" I know that comes out and the key goes into it but what is the "ignition switch" ? Is that the whole assembly including the lock cylinder that is held in place by the two bolts?
Would the lock cyclinder come with it? Thanks for all your help and suggestions.
Old 10-17-2007, 03:36 PM
You are welcome mate.
If the ignition lock is good and tight to the steering column, no moving around, then it sounds a lot like your lock barrel is sticking, not letting the key back to the default position.
This is backed up by the fact that when you took it off and cleaned it, that it worked OK for a month.
Next suggestion, take it off again, and soak it in a solvent. Methylated spirits from a pharmacy will do, or paint thinners might be better. Soak it overnight in a glass of solvent. Next morning give it loads of opening and closing with the key, if possible while in the solvent.
I suspect that the lock may have been lubricated at a previous trip to the dealer. The lubricant used attracted dirt and turned into a gum inside the lock. The above soaking will shift the gum from your lock. When your lock has freed up and should no longer be giving colour to the solvent take it out and dry it off. Leave it somewhere warm to dry the inside of the lock. Then use Dry Graphite on the key and into the lock. This will keep the tumblers lubricated inside without turning to gum. It'll blacken your fingers for a bit, but no worries.
Put it back on now, and hopefully you may have no more trouble. When fitting it back make sure you have all the electrical connections plugged in the right places and secure.
Hopefully that sorts the problem for you.
Old 10-17-2007, 08:45 PM
I had someone tell me they had the same problem. When I checked it, I found that they had stopped the car and it was still in gear. When I shifted it into neutral, the key came out just fine.
Old 10-18-2007, 02:40 AM
Joe... his needs replacing. Trust me on this... I experienced it with Hondas, BMW's and Mercs...
When the ignition experiences such symptoms... it means it is telling him goodbye
Old 10-18-2007, 02:58 AM
You are most probably correct Danny, but it is worth a try if he can't get a new one quickly.
Old 10-22-2007, 02:25 PM
thanks
Thanks to all your suggestions. I got a new barrel lock. Finally figured out how to aleign(sp) it correctly so it would slip in. All works well now.
Old 10-22-2007, 03:19 PM
Glad you got it sorted. It is one of those things that is both a nuisance and a worry.
