fuel pump removal
grr!!, i need to replace my fuel pump but im having trouble get the fuel lines off and i dont know how to open the cap to the tank!! it looks as if u twist it but it wont budge, i have the manual that tells about the removal of the pump but it doesnt say how to open it up, anyone got some tips??
never done it on a sub, but they usually take a drift or a flat head and a hammer.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." |
If you're thinking that replacing the fuel pump might correct your rough-running problem, my guess is you're doing a lot of work for nothing.
dcb |
i have bad hesitation problems but go away once my fuel is low, ive heard from several people my pump is bad, i got a good one off a 91 legacy, havent installed it yet, will reply if it works.....
Re: fuel pump removel
Does anyone ever finish their threads???
That is one of the things that can make searches frustrating. Come on guys.
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
Found this in a manual, though it doesn't really specifically say how to remove the cap over it:
-Unscrew the plastic retainer that holds the top on the tank in place -Pull up on the lid and remove the hoses and connectors -Remove the gold colored metal retaining clip -Remove the fuel pump assembly The pump is usually screwed or clipped to the assembly bracket, as well as to the fuel line and pickup strainer. Subaru has a special tool to remove the fuel pump cap, but it doesn't look all that special IMHO. Pic attached. |
Well that's neat, but there's no way that tool would fit on my cap as it was not centered in the access panel.
If I were to add to those instructions just for the sake of being specific: -Unscrew (counter-clockwise) the plastic retainer that holds the top on the tank in place. Impaction force may be necessary. -Pull up on the lid and disconnect the lower end of the two softer hoses and 2 upper connectors -Remove the brass colored rectangular metal retaining clip. There are four tabs securing it to a plastic fixture. Looking towards the back of the car dislodge (by pulling outward) the 2, 5, and 7 o'clock tabs as the 10 is too cramped even for someone with baby hands. -Remove the fuel pump assembly by lifting and rotating it. Remember which way it came out because if not put back in this way the filter will get caught on a green wire and something that appears to be a cornbread muffin on the bottom of the left side of the tank. Here is a picture of the clip, because in my opinion it was not very obvious at first:
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 01-16-2011 at 02:21 PM. |
I have to admit, I was reading through those and the part about "something that appears to be a cornbread muffin" made me chuckle
Great job on the picture of the locking clip NikFu.
It's not exactly obvious the first time one sees it down in the tank. Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
Just removed a fuel pump from my 92 yesterday, but I haven't gotten a replacement quite yet. The problem I have is that the pump runs but it doesn't pump any fuel - I even checked at the lines coming right out of the pump.
So I pulled out the pump (NikFu's pic was very helpful), and - after successfully dropping that clip in the tank, fishing it out, and almost doing it again - gave it the ol' ball-peen tune up, but still nothing. Now I have heard that sometimes if a fuel pump is clogged you can get it to sort of unclog itself by running it in reverse with a jumper pack, so i figured it would be worth a try on an otherwise useless pump, but that was no good either. Anyone else know if this ever works? I'm just curious about it at this point, because I'm guessing that my pump failure is due to some internal parts failure. |
If you've got it out I would just replace it.
I would also attempt to take it apart and service it, but I am like that.
FINALLY replaced the fuel pump and got the ol girl runnin today.
And as a side note, I took apart the old one just to see what went wrong. Found out that the pump seized up, and there's two tabs on the rotor that powers the pump - both of which snapped off after seizing. I'm thinking plastic parts weren't the best decision the engineers made that day. I took pictures while i was dismantling the old pump if anyone is interested - now i just have to remember where that camera went |
Thanks for the pix!!
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Re: fuel pump removal
Ok, this is probably a lame question....but why does it look like 2 FP's in the tank?
I see a standard Subaru cylindrical pump with the sock on it, then theres the black square one that has the clip on top like shown in Nikfu's pic. Which one do I replace?
Verified Females |
