Old 11-01-2007, 06:35 PM
cruisen_15's Avatar
cruisen_15 cruisen_15 is offline
can someone explain...
if i put a new spark plug on a bad coil the engine backfires irradicitly and if i put an old nasty plug on it has 50% less backfiring and spuddering??
Old 11-01-2007, 06:44 PM
SomethingElse's Avatar
word words wording
I cant esplain it.
need more info.
are you sure its 50%?
Eric
Old 11-01-2007, 06:51 PM
cruisen_15's Avatar
i have bad backfiring and hesitation, had a CEL for misfire for cyl.2, put new spark plugs in and ran twice as bad with backfiring and spuddering, i changed just that one bad coil with a previous old spark plug that was on it, now to runs with the same old backfiring and hesitation, i know its a bad coil because i took it off and looked at it while i cranked the engine, 1 out of 10 times i cranked it, did it actullay make a spark.... im trying to put this in best words...., so why is it that if it has a good plug it causes even more backfiring and spuddering then if i have a old nasty plug on.... also when i rev it, it makes a whirling noise and quickly decends rpm after i let go of gas, my opinion is that its only running 5 cyl. and with a good spark plug its combusting the fuel every other cycle or two..... and the bad plug doesnt even ignite the fuel....., and my exhuast is really white...... and smells like raw fuel anytime on start up...... anyone get what i am saying??
Old 11-01-2007, 08:04 PM
Turbone's Avatar
Turbone Turbone is offline
Send a message via ICQ to Turbone Send a message via AIM to Turbone Send a message via Yahoo to Turbone Send a message via Skype™ to Turbone
If you know the coil pack is bad, why did you put a new plug in?
You need to change out the coil pack and be done with it.
Verified Females
Old 11-01-2007, 08:19 PM
cruisen_15's Avatar
i thought it was the plugs at first, considering they needed to be changed anyway, i did the test of the coil pack after i had baughten the plugs, Turbone , do you agree with my oppinion or do you have any other ideas??
Old 11-01-2007, 11:33 PM
Turbone's Avatar
Go ahead and change all the plugs and install another coilpack. Should cure your misfire.
Verified Females
