Blowing of 20AMP fuse for Cig Ligther
I have found out why mine has kept blowing. The Cig lighter after its years would turn slightly and make the inward and outer casing touch causing the short and thus blowing the fuse. I have unplugged my lighter and haven't had an issue again with it blowing. I hope this helps other people.
Re: Blowing of 20AMP fuse for Cig Ligther
Keith |
I have 2 power connectors (1 for my cell phone and 1 for my GPS) I never have an issue with my GPS one... but with the cell phone I've blown 4 fuses.
Something about pushing it down too far makes it blow... or inserting it down hard rather (spring like) for longer than a second will blow it. I'll have to see if this is similar as to why it's happening but doesn't make much since why it would only do that on the cell phone charger...
1994 subaru svx le 112k |
After 17 years my cig lighter decided to separate at power supply connection. The only thing I used it for was to charge the cell phone, well, I now charge it in the house. It looks like the way to reconnect the power wires to the lighter is to remove the console, no thanks.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
You might be able to reach behind it if you take the ashtray out but not sure. I have the actual lighter in mine just to plug the hole, I don't smoke but even if I did I sure as sh*t wouldn't smoke in my car, not just cuz of the gagging old smoke smell, but also the risk of melting or burning holes in the interior, and that icky film that builds up on the windows. (I've worked on cars that I've had to spray deodorizer in before I could even get in them to move them into the shop they smelled so bad)
I smoked for 28 years, quit 20 years ago. I couldn't believe how bad my clothes & car smelled after my nose started working normally.
I have disconnected it and have even removed it from the spot. I pull the power mirror switch nothing new. I have noticed if you pull the clock fuse the beeper stop if you leave your keys in the ignition. I'm really going crazy.
Its weird. I'll put a new fuse in and turn the ignition and the the clock lights up for 2 - 3 seconds and then it blows. It doesnt blow right away. I remove the clock. AC , and Radio fuse and it still blows. I don't know tomorrow I will pull apart my radio but I don't get why it would keep working or not blow the Radio fuse. Any had a problem like this?
it might be the constant power supply wire for the radio is causing this problem. When I installed my radio I had an almost idenetical problem. the constant power supply is not linked to the radio fuse( that I am aware of) as when I pulled it back out and reconnected the wire differently it hasen't happened since
William Last edited by subarufamily; 08-19-2008 at 09:14 PM. Reason: spelling of word |
