Ball joint with grease fitting?
Well I am still trying to chase down some front end noise. The latest is greasing the front ball joints with a needle into the boot. This has helped.
Has anyone tried to drill and tap so that a grease fitting can be added to the ball joint? I have an old set and I was thinking about trying.
I can't imagine it would be a bad idea. Just be sure to deburr the hole really well after drilling and tapping. Aren't those joints supposed to be permanently lubed? I never understood how they got away with that stuff.
Johnny
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX) Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting. Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well. You can tell the lack of craftsmanship by the wrinkles in the duct tape. |
New Ball Joints are less than $75. I would recommend replacing them instead of using grease as a band-aid fix. If there is noise present, that means that there is excessive clearance from wear. Grease will only mask that noise for a short time. Replacing the joints is relatively cheap and is very easy.
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock |
Now if you were to drill into a new joint and adapt a grease zerk you would want to pack the flutes of the drill with grease in order to capture the tailings. Most grease zerks are self-tapping, so once the hole is made you'd be home free.
Thanks for the reply.
Yes I also think that the old joints are worn out and need to be replaced. I want to do this because I think they only last about 30k miles depending on the road conditions. I think that having new joints with grease fittings would be great. Then the joint should last a very long time. I think that putting a hole in the ball would be very much no good at all. So this is why I am thinking about using the old joints that I still got. You know for a test case. If the BJ is made similar to the inner tie rod ball joint then there will be some sort of "plastic" under the steel ball. I am hoping this will make it easier to decide when to stop drilling. The other reason for wanting to do this? Someday the new BJ supply will end.
