Old 10-22-2002, 08:41 PM
$VX
A few general concerns....
I think I have a little bit of the binding problem... I tried to look out for it when I bought the car, but I didn't really know what I was doing that well (the descriptions I got weren't that accurate oh well)...but... when the wheel is turned pretty far, and I' have to accelerate, like, for example, from a parking lot entrance out onto a street, theres sorta a stutter type feeling/noise. I'm guessing thats 'binding'. What causes this?
Also, between gear RPM flares... I read that the 'flare' in the RPMs is caused bya dirty or bad throttle position sensor... if I recall they're about 150 bucks. How are my chances at cleaning one and putting it back together?
Lastly, when I park on a hill so the SVX is pointed upwards (on my mothers driveway) I get in the car, start it, put on the brakes, take OFF the aprking brake, and then put it in reverse. As I'm backing up, like 2 seconds after I start backing up there's a weird noise. It only happens when I park on a steep hill upwards like that. Any ideas?
Thanks guys!
- Ca$h
Old 10-22-2002, 09:43 PM
Green1995SVX
OK... first, that does sound like what binding is. It is caused when the transfer clutches (READ: center diferential) are locked together. This causes perminant 50/50 torque split. The problem with this is all the wheels are spinning the same speed at the same time. because when you go around a corner, the outer wheels need to spin faster to keep up with the inner wheels, it causes this binding.
The shift flares could be normal. The svx is programmed for very smooth shifts which can be mistaken for slipping. Try unplugging the resistor next to the battery (on the inner fender wall) and see if the 'flares' go away.
I have no idea about the last prob.
Mike
Old 10-23-2002, 12:16 AM
subymtnguy's Avatar
subymtnguy subymtnguy is offline
"high" in Colorado
binding....
Cash,
see my thread "Hey Beav" in this forum......
my binding problem is now gone!
92 Liquid Silver LSL
85 BRAT GL
81 280ZX
91 Legacy wagon
86 Pontiac Parisenne (55k)
86 Kawasaki ZG 1000 Concours
81 KZ 1000 LTD (shaft)
Old 10-23-2002, 07:06 AM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
The last problem is the ABS doing its self test.
It does that every time you start the car and move it, but it is not so noticeable on flat surfaces.
'20 Honda Ridgeline
http://www.x35design.com
Old 10-23-2002, 07:39 AM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
shift flares: The SVX actually turns off one bank of cylinders during each upshift to allow for smoother shifting, this is what you could be noticing.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 10-23-2002, 12:34 PM
$VX
No, in the general SVX forum SOLARSVX got his transmission replaced, and his mechanic advised him to get a new TPS sensor.... becuase these 'flares' in the RPMS could damage the transmission. Do you remember that? I think Aredub agreed and they both replaced their TPS sensors.
- Ca$h
Old 10-23-2002, 05:07 PM
$VX
Is this 'ballast' thing in the transmission easy to get to? I'm pretty competent.
- Ca$h
Old 10-23-2002, 10:52 PM
-mike
Mike it only does this when moving from park to D or R, if the rpm is over 1200 rpm( I think it's 1200 could be 1500). So that it does not bang into gear.
Old 10-24-2002, 12:27 AM
gcookaustin
- Ca$h
Mine does the flares as a result of the TPS. Cheap solution: keep RPMs at 2k or greater during 2-3 shift. I usually shift it manually anyway, that way it does less "shifting" which should mean less overall wear on the clutches and less heat and such.
Old 10-24-2002, 05:59 AM
Hmm that's not what I read but I could be wrong.
-mike
Old 10-24-2002, 06:59 AM
troth
ok manual shifting
is manual shifting easier on the tranny? My guess is yes but I'm looking for opinions..
thanks
tr
Old 10-24-2002, 08:57 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Mike
Just a note: I delineate "Hold" as a "normal" shift and "Flare" as an abnormal shift. In other words, during a normal shift, the tranny "holds" at about 3 G's on the tach (at shift point), then the needle drops. In an abnormal shift, the tach "flares" from 3 G's to 3.5 or 4 G's before it shifts (there's no doubt that there's slippage) and the needle drops. So, "flares" would not be normal.
Randy Johnson
Mike Davis -- at Reading VI
Old 10-25-2002, 12:30 AM
gcookaustin
Re: ok manual shifting
thanks
tr
If you know what you're doing, yes. Pretend you're the car, would you want somebody mashing the gas pedal while you're trying to shift? Nuh uh. I usually start out with the gear shifter in 2, since the 1-2 shift is pretty sharp, then I accel to 25 mph or so, and let off of the gas a little bit and put it into 3, and the same for D if I get going ~50 and I know I'm not going to have to slow down for a red light ahead or whatever.
Old 10-28-2002, 05:10 PM
troth
thanks
will rig a fuel cutoff on manual switches! just kidding but what the hay!
tr
