Old 06-01-2018, 05:37 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Stock ECU location
Still got my CEL 45 error - atmospheric pressure sensor.
(anyone managed to fix the same issue on their SVX)
Wish to open mine up and check what might be a capacitor issue - anyone know what pin the sensor is linked to ?.
TIA
Old 06-01-2018, 09:27 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Re: Stock ECU location
It's up sort of under the steering wheel area. Small hands and ratcheting 10mm wrench make it slightly less unpleasant...
'20 Honda Ridgeline
http://www.x35design.com
Old 06-02-2018, 01:38 AM
SURTEESS's Avatar
Cannot find ECU or atmospheric sensor in section 6 of the FSM ?.
(I have a full set + yearly updates).
Anyone got any ideas? also what type of sensor it could be?.
TIA
Old 06-02-2018, 09:40 AM
Stevebsy's Avatar
Administrator
TIA
It's in section 2-7 page 95 in my book.
Unfortunately it says "When trouble code 45 appears on display, replace ECU"
It is inside the ECU housing
Here's an old thread on ECU removal:
http://www.subaru-svx.net/forum/show...023#post651023
'20 Honda Ridgeline
Old 06-02-2018, 04:15 PM
SURTEESS's Avatar
Steve,
found it - yes you are right.
Now all I need is a spare ECU from this side of the ditch, so I can PnP with mine, then work through what the issue is with mine? - I suspect dry/leaking capacitor similar to my A/C controller that I fixed a couple of years ago.
So has anyone got a spare they are willing to donate till I get mine fixed, will return the unit afterwards - would prefer someone in this part of the world (eg non-USA type with p/n 22611AA710 or 22611AA711).
Thanks again.
Old 06-03-2018, 07:29 PM
RisingPhoenix RisingPhoenix is offline
So? Does the car run and drive good?
I've been driving my 1992 American SVX with the 'CHECK ENGINE' light on for 10 years...car always runs great!!!
But if it does cause some annoying 'performance' issue while driving, I'd install an inline capacitor to override the problem.
Old 06-03-2018, 10:07 PM
SURTEESS's Avatar
The cars drives well, apart from when the weather starts getting a bit cold - hence the atmospheric sensor issue showing CEL 45.
I have now had 2 people here in NZ loaning me 2 ECUs so that I can fault find the issue with mine (really want to keep the original ECU with car).
Does anyone know what the atmospheric sensor is / where located / signal type is, to the ECU ?.
I am hoping that the issue is a dry capacitor...will keep you all posted.
