Old 10-11-2002, 02:12 PM
padrotte
whole panel is out
My clock, air conditioner, and cigarette lighter don't work all of a sudden. My radio works and that's the only thing that does work on that panel. Checked the fuses but that doesn't seem to be the cause, anyone else have this problem or have any suggestions for the fix? I did replace the factory stereo but the stuff was still working for a while afterwards... Thanks in advance.
Old 10-11-2002, 02:23 PM
cjoffe
I just had this happen the other day. I checked all the fuses and wiggled all the relays. I don't know if it had any effect, but everything came back on when I started the car.
Let me know if you find a cause.
CJ
Old 10-11-2002, 02:42 PM
mattski mattski is offline
Re: whole panel is out
Had similar symptoms with my Aerostar when a local "expert" shop installed a new radio. It worked great until the power wire, which was pinched, wore through and blew the panel fuse. It sounds like you have not yet found the blown fuse.
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 10-11-2002, 02:59 PM
cjoffe
The weird thing about mine is that's what I expected it to be but no fuses were blown. I pulled several (under the hood only, not inside the car) and replaced them. The problem only manifested itself once and went away on its own.
CJ
Old 10-11-2002, 03:04 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
That's usually fuse #3. I had this problem before, also. Check your wires to your sunvisor mirrors (remove the little "elbow" covers and see if there are any bare wires).
Randy Johnson
Mike Davis -- at Reading VI
Old 10-11-2002, 03:09 PM
cjoffe
By replace, I should have said "put them back". The original fuses are still there.
Is fuse #3 in the car or under the hood?
CJ
Old 10-11-2002, 03:14 PM
Aredubjay's Avatar
CJ
It's in the car.
Randy Johnson
Old 10-11-2002, 03:15 PM
CJ
In the car
Old 10-14-2002, 03:25 PM
padrotte
thanks for all your help but is the #3 fuse in the fuse box by driver's left leg? because it doesn't look like those fuses are numbered...
Old 10-14-2002, 03:28 PM
cjoffe
I had the panel do this again yesterday, but it came on within about 10-15 seconds on its own.
Still confused.
Is there a relay that controls power to this panel??
CJ
Old 10-14-2002, 03:47 PM
padrotte
k, i got it, it was the 'Cigar/Mirror' fuse. I just went through all of them. I'm in all your debt.
I've been lurking since i got my SVX in July. Sweet machine, dark green (teal?), spoilerless, 107000mi (at purchase), rebuilt tranny, $4,000. I'm going to CU at Boulder and saw two other SVX's out here.
Old 10-14-2002, 03:56 PM
Aredubjay's Avatar
Yep, that's fuse #3. Sorry I didn't respond before now. Fuse numbers should be located on the cover, however, if you have the problem again, as you look at the panel, starting in the upper left corner, the fuses are numbered:
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
Randy Johnson
Old 10-14-2002, 03:59 PM
cjoffe
That's good to know that was the problem. Did you find any shorted or bare wires??
Anybody have any thoughts on my intermittent failure???
CJ
Old 10-14-2002, 04:02 PM
Aredubjay's Avatar
CJ,
I can't think of anything beyond what I've told padrotte. Anyone else?
Randy Johnson
Old 10-14-2002, 04:40 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
The CD player and the AC controls are on different circuit. AC dying can be caused by a loose wire under the fusebox. Check that first. As for the shot, you can tell. I smelt the burnt fuses the whole week with my new mod.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
