Old 02-01-2016, 08:07 PM
carlhoffmann carlhoffmann is offline
speedometer
odometer working..speedometer NOT working ?
Old 02-02-2016, 12:08 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: speedometer not working
Carl,
I will check in the USA service manuals tonight, I am sure this has been noted before? Anyone....
Also edit your title to make more like mine....
Old 02-03-2016, 09:22 PM
trueblue's Avatar
trueblue trueblue is offline
Send a message via AIM to trueblue
Re: speedometer
Got the same problem with mine. It started after I had a new trany installed. The car sat for three years before the install, I suppose the down time could have affected the speedometer.
[SIGPIC][/SIGPIC]Kenyatta
The farther backward you can look, the farther forward you are likely to see. -Winston Churchill
My baby: 94 lsi
My fast baby: 2001 Suzuki Marauder
My new baby: 2010 Subaru Outback
Old 02-05-2016, 12:59 AM
ShaneHobson ShaneHobson is offline
Re: speedometer
speedo not working at all or not working above 50kph ?
Old 02-05-2016, 05:33 AM
Re: speedometer
sometimes speedo sticks at 10 kms and sometimes nothing...carl
Old 02-05-2016, 04:25 PM
Re: speedometer
vehicle has been stored for 8 years.
