Old 10-04-2002, 03:10 PM
lee lee is offline
Thanks for the opinion Beav,
I've never added an aftermarket gauge to a car except a tach back in the days of big block MOPARs.
I've generally felt like I worry without a gauge, but worry about what the gauge is saying too - since I could never decide - I took the easiest route - don't buy it then if you can't make up your mind.
I continue to struggle with the idea of a tranny temp guage, but then again it's such a frequent topic here I get paranoid.
Old 10-04-2002, 04:12 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
That's o.k., a lot of people think that since I'm a mechanic I should have a full set of tools in each of my vehicles. To tell the truth, you'd be hard pressed to find a screwdriver in my car. If it breaks on the road you'll find me waiting for the tow truck while sitting in the closest bah.
Old 10-04-2002, 07:16 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
I dont understand why you would need to monitor the A/f ratio in a naturaly aspirated car. The computer should be doing an adaquate job as long as you are not altering pressure levels. I used one in my eclipse in sync with my boost cotroller/guage to make sure i wasnt running to lean or even the slightest bit lean on WOT.....after all nobody likes detonation Especially PDQ gas
phil
~Phil
Old 10-04-2002, 07:19 PM
Green1995SVX
Because they look cool.
Mike
Old 10-04-2002, 09:09 PM
Invisible avatar
Smile
Mike
All this gauge talk somehow pulled an old image out of the old mushy hard drive between my ears. Back when I, as a kid, would visit the the corner drug store twice a day anxiously awaiting the arrival of the latest issue of Popular Mechanics, the geek mag of its day; I read an article about a WWII fighter pilot who decided his '50 Buick needed all the instrumentation of the Hellcat, or whatever he flew during the war. I'll never forget the interior photo. There was the windshield & top of the dash. A steering wheel was visible. The rest of dash area & below from door to door was nothing but analog (yeah, not digital, Ron) B & W gauges. Just why a '50 Buick needed an altimeter is besides the point. It looked wild, & the owner was happy.
Besides, '50 Buicks didn't have funny windows to gawk at.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 02-15-2003, 07:38 AM
immortal_suby's Avatar
Thread Killah
Hey mike - are you still using this gauge? I'm thinking of getting one and also one of the e-bay scam item 20hp mods just to see what it is actually doing to the air fuel mixture.
Locker Link
2015 BRZ Limited 6MT
Old 02-15-2003, 11:09 AM
Phast SVX's Avatar
hate to brake it to you but there is no way in hell you will see a difference on WOT,an a/f only mesures stoich conditions on wide open throttle, it will bounce from lean to rich the rest of the time on partial throttle. Ill tell you right now what it will do and save you the money. When you go WOT with that stupid thing in, it will go to the same DAMN bar it always does, guarunteed. In my GST i could raise boost by a PSI and have roughly the same stoich conditions assuming i had decent gas. Not untill i started to reach 2-3 psi difference did you start to lean the mixture out. that little resistor thing would just make you mad for wasting the money. Save it for a wheel bearing or somthing If your really hung up on this considering buying an egt(engine gas temp) probe/guage, and see what the conditions change to with the resistor in, should give you any change in combustion conditions more accuratly. higher temps= leaner, lower=richer
phil
~Phil
Old 02-15-2003, 05:38 PM
Subafreak's Avatar
Superbeast
Thats what I was gona say. Takes A little more knowledge to read but much more usefull. Autometer even makes one with duel inputs.
