Old 03-04-2014, 04:25 AM
carlhoffmann carlhoffmann is offline
wheel nuts
the garage servicing my car wanted to replace 2 wheelnuts, subaru nz quoted $60 plus gst each..no wonder i purchased a new nissan murano as my daily driver. it could have been an outback.
Old 03-04-2014, 08:37 AM
Re: wheel nuts
I have spares if you're not in a rush. I won't charge you $60.00 each either.
Is the thread backwards in New Zealand?...
Old 03-04-2014, 01:09 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: wheel nuts
!!!! aH aH
Old 03-05-2014, 05:02 AM
Re: wheel nuts
the guy that changed the wheel and sheared off two wheel studs and jammed them in the wheel nuts must live on the equator and thought the thread was sideways..
Old 03-06-2014, 10:47 AM
ShaneHobson ShaneHobson is offline
Re: wheel nuts
Hi Carl,
I can send you a couple of wheel nuts, I still owe you for the Dr Tranny's so it's the least I can do. I've found your address by looking in Google Maps.
Your place is easy to spot, it's got 8 SVXs parked outside :-)
Shane
Old 03-06-2014, 06:11 PM
Re: wheel nuts
not 8 but now 9.as my pension cannot afford my lifestyle i will reduce them to 5.. i need 8 wheel nuts...all donations accepted....wrote a letter to the gm of subaru about their pricing got a reply...wish adam was there.l
