Old 12-14-2013, 01:55 AM
danielparker danielparker is offline
JDM TCU Wanted
Hi,
I have damaged my TCU (Transmission Control Unit) and need a 'new' one..
My SVX is a Japanese Import, so I need another from a JDM model.
Can anyone help?..
Old 12-14-2013, 02:44 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: JDM TCU Wanted
Wow, that looks unusual - anyone else got the english equiv. (and what does it mean?).
Old 12-14-2013, 11:42 PM
Re: JDM TCU Wanted
Its two errors.. one says 'Diff Lock'.. and I don't know what the other says.
I have fixed my TCU (Damaged track caused by a modification I was doing), so the pressure is off finding one.
Daniel
Old 12-15-2013, 11:58 AM
Crash_Bandit Crash_Bandit is offline
Re: JDM TCU Wanted
The kana says "sentaa difurakku".
So most likely center differential lock is what it means.
-Ash
96 Polo Green - Daily Driver
92 Teal Green - Restoration in progress
Old 12-25-2013, 10:35 AM
ShaneHobson ShaneHobson is offline
Re: JDM TCU Wanted
Confirmed by checking my NZ instrument cluster.
It says Diff Lock in the same location.
Old 04-04-2020, 09:06 AM
SURTEESS's Avatar
Re: JDM TCU Wanted
Shane,
are you trying to do a switch in order to get diff lock working when you want manually ?.
It would be interesting to know what the wiring would be in order to do that.
