Old 02-11-2013, 06:27 PM
shotgunslade's Avatar
SVX Emblems from 94 LSi
I am getting a complete respray of my '94 and Dave Heinrichs says he can't save the emblems on the rear panel behind the door. Here is what they look like.
Anyone has these, left and right side, I'm in the market. Thanks.
Old 02-11-2013, 06:48 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: SVX Emblems from 94 LSi
part# J1210PS040 $53 bucks a pop on subaruparts.com
Wanted: Steering Wheel
Old 02-11-2013, 06:57 PM
Nah, looks better without them.
At least for $106 it does.
Old 02-11-2013, 07:03 PM
Really? The heat gun + fishing line debadging trick won't work?
Old 02-11-2013, 07:15 PM
Crazy_pilot: Tell me about the heat gun + fishing line debadging so I can forward the information to Dave.
Thanks, Michael, for the part number.
Old 02-11-2013, 07:29 PM
It's pretty simple, although generally used on smaller badges than the SVX one.
-Use a heat gun to warm and soften the adhesive. Might want to take it easy with this part on your badge, since it looks like it's laminated plastic. And obviously the underlying part is plastic as well.
-Slide fishing line between the badge and the car and use a flossing/sawing motion to cut through the adhesive. Some people have actually used dental floss for this as well.
-Clean the remaining adhesive off the car with Goo-Gone, acetone, or whatever solvent you prefer. Even easier since you're repainting and won't worry about scratches.
If you look up "debadge a car" on Youtube you'll get lots of hits.
Old 02-11-2013, 07:35 PM
They should have no problem getting these off.
And IMO, they look better without them. They were a US only item used on 94+ LS fwd, LSi and (maybe) L AWD's added for who knows what reason.
Old 02-12-2013, 05:51 AM
theflystyle's Avatar
I have thought about leaving the SVX part and removing the Subaru from the emblem.
1994 SVX LSi
2008 Legacy 3.0R
Old 02-28-2013, 07:44 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
I've always been aggrivated by the cheapness/look of them, despite the fact that I actually like it and feel that it's fitting to be there. I've always wanted to do something custom with that.
1994 subaru svx le 112k
Old 03-01-2013, 05:41 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I would vote to debadge for the cleaner lines. Can't wait to see the final result
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
