Old 12-09-2012, 08:09 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
WTB: GOOD rear suspension components
I have ridiculously saggy rear springs, and I'd like to get new ones and put them in over Christmas break. I want used ones from somebody here. I realize it's dumb to put used parts on a used car, but I don't care. I can't afford an entire new strut assembly, and when I do I will be going with a set of coilovers, not the stock ones. So, does anyone have a really good, sag-less set of rear springs they'd be willing to part with? I'm not paying an arm and a leg for these things. They're only $70 a piece brand new from Subaru. But, considering my struts, mounts, etc are all 21 years old, I'd rather just get by than putting new parts on a crappy strut.
Also, if anyone have the entire strut assembly (tower, spring, mount, etc) let me know what you want for that as well. I'm really tired of people asking me if I have a lowering kit on the back.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 12-09-2012, 09:25 PM
92 SVX 92 SVX is offline
Re: WTB: GOOD rear suspension components
I have my stock rear springs but I think my might've been sagging course with blown struts they could have been the cause.
$40 + shipping sound good? I'll add a pic you decide if they sag
This was taken shortly before I put in a set of motorsport lowering springs, in late 2010 I believe. I do have good top hats but the struts are shot.
Old 12-09-2012, 10:04 PM
B 4 You's Avatar
#lolsvx
Do you have a picture of the top hats? I'd rather get springs from a 97 since they're 5 years newer. Yours look like they're just about to start sagging.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 12-09-2012, 10:18 PM
I will get pics tomorrow, they are in the crawl space over my garage, too late and dark to try getting to them. Oh and good is a relative term, the ones I have may have slight surface rust but they are still solid and not starting to collapse.
Ya I dont blame you getting 21 year old springs may not solve your problem
Old 12-10-2012, 10:12 AM
B 4 You's Avatar
#lolsvx
Heck, if they're not ruined I'll throw some spray on undercoat and hope for the best.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 12-10-2012, 10:53 AM
processengr's Avatar
Are your top mounts rotten through? It is really common. When this happens, car will sit ~2" low. Maybe this is what has happened rather than the springs sagging?
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 12-10-2012, 11:32 AM
B 4 You's Avatar
#lolsvx
Yes, I can guarantee they are shot. Going over a gravel parking lot sounds horrible. Little driveway bumps are loud as well. I think the car is more than 2 inches lower than it needs to be... I've got 225/55/16's on the stock wheels for winter and the fender is about 1-2" above the lip of the rim. The reason I think it's the springs too is that big bumps sound like the springs are completely collapsing. I think it's the springs and the top mounts both honestly. I don't wanna replace the top mounts and then have the car still sitting that low in the back. It looks really weird.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 12-10-2012, 11:49 AM
There is a rubber spacer called the "helper" with a disc called "helper guide" that prevents the spring from stacking on full travel. The rubber spacer tends to split and disintegrate, and the guide disc rots out/away. This is likely the cause of the springs "bottoming". The helpers are ~$20 each and the disc guides are ~$12 each from subaruparts.com
Cheers! Gordon
2018 Tesla M3 30k
Old 12-10-2012, 12:24 PM
B 4 You's Avatar
#lolsvx
That's a possibility. But my biggest concern right now is getting springs to push the car back up to its normal ride height. I keep bottoming out and it's making me uncomfortable. If newer, stiffer springs (and top hats if I can get some) don't do it then I'll go onto all these little rubber pieces. I just don't want to spend a lot on this soft, comfy suspension. I want to invest in a really nice set of coil overs. Thanks for all the advice though.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 12-10-2012, 12:46 PM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
I have a '97 with about 74K miles on it, no sag. I'm waiting for my coilovers to arrive from AMR and he said they'd be here by Christmas. When they arrive, I'll have them changed out by my mechanic and sell the originals. I wouldn't need much more than shipping and hassle expense of boxing and shipping. Only problem is timing. AMR just had some problems with shop equipment and there may be a delay so putting them in your SVX over Christmas might not be possible. And shipping might be prohibitive, IDK.
Old 12-10-2012, 01:14 PM
B 4 You's Avatar
#lolsvx
I can't be all that picky. I'd rather wait for a low milage '97's good springs than get a set from a '92 that's going to sag by next winter, too.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 12-10-2012, 08:19 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
My car is doing the same as yours...
My idea was to take the springs off my parts car an weld them on top of the springs I'm currently using so I have twice as much height
That should give me clearance to get over the muddy ruts in the driveway
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
