Need water pump, radiator
first off, is this ebayer ok http://cgi.ebay.com/ebaymotors/1992-...item4aa8b522f5
second, need a water pump this a good deal? I also need belt http://cgi.ebay.com/ebaymotors/92-97...item3cb547d587
1992 Subaru SVX: sold after months of problems. 1995 Volvo 850 T5R sedan 2011 Subaru Outback 3.6R limited: excellent all-rounder Last edited by 3.3H6; 03-31-2011 at 07:05 PM. |
Re: Need water pump, radiator
I saw that radiator listing earlier tonight. It's an excellent price if it's an OEM rad. I'd send him an email to confirm. There are good Chinese copies available for around $100-130.00, I bought 2 of them and they have worked well for a couple of years.
Most people recommend a genuine Subaru water pump but the Ebay belt and pulley kits seem to be fine. |
1992 Subaru SVX: sold after months of problems. 1995 Volvo 850 T5R sedan 2011 Subaru Outback 3.6R limited: excellent all-rounder |
Some people will swear that it's the way to go (cheaper non oem) and have had no problems with it all... others will be quick to point out the ebay water pump sucks (it does, trust me)... To answer your original question: Is it a good deal? No.
1994 subaru svx le 112k |
My advice is to go OEM with the waterpump and gasket. I had good luck with ebay timing kits on at least 5 different SVXs.
1991 SVX L JDM |
I got one of the Chinese radiators and it crapped out on me after about a year. I wouldn't recommend them to anyone.
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
Ultimately I think it was a combination of things causing the timing belt to break... not the idler's though as the new belt is just fine with the existing idlers. The water pump seemed terribly unbalanced (due to the casting) cheap shoddy job, which I can only imagine created some sort of pull/tug like jerking motion at high speeds... I had 2 pulley's seize on me (both belts broke) and the power steering pump fail (creating more stress I feel on the overall engine) but it finally crapped out a few months after having everything completely fixed.
OK, updated parts list as of today
(if stuff is listed twice with different name, I'm going by two lists) Timing Belt Tensioner (185.13 NAPA) Idler pulley (72.15 PartsPlus) Timing Belt (108.23 PartsPlus 80.81 NAPA) Water Pump (new) (103.31 Napa 232.11 PartsPlus) Water Pump (remfd) + core (69.27 Napa) CV boots Left inner (24.62 NAPA) Power Steering Return Hose (18.14 NAPA 13.38 Parts Plus) So should I go for the radiator I linked earlier or not? I just need something to replace the old one with, which is ruined. BTW one of the instructors working on the car wanted to know if the front CV shafts from a legacy will fit an SVX.
I think the Ebay radiators are worth a try. You might get a good one, and the only other options are OEM, used, and PWR.
SVX axles only. Get the new "fwd" axles from autozone or Advance, can't remember which one, but they're $70 brand new. And no, no other axles will work.
Not true...
...at this point I don't care if my radiator is made by subaru or a bunch of chinese children, I just need a radiator for around 100 bucks so I can get this damn thing running before the end of the semester.
I have a Chinese made one. Bought it about 2 years ago. Still works fine...
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
right, then I'll get one.
Thread Tools | |
Display Modes | Rate This Thread |
