Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 12-03-2010, 01:15 AM
FlipC FlipC is offline
Light Weight Trunk?
Just what the title says.
The OEM weighs a ton.
Old 12-03-2010, 06:24 AM
Re: Light Weight Trunk?
Does not exist to date.
Old 12-03-2010, 07:31 AM
Remove the wing, get your dremel out and trim out all the bracing. Voila, best you're gonna get.
Is it just for opening that you find it heavy? Chances are your trunk struts are shot. It should be able to hold itself open at about a 45 degree angle.
Old 12-04-2010, 01:12 PM
Yes the struts need replacing but the trunk is still very heavy.
I didnt find anything while searching so I wanted to see if anyone ever did a custom carbon one.
Old 12-04-2010, 02:08 PM
Cam Cam is offline
Someone took theirs off and threw it on a scale. The result was surprising. I don't think it weighs as much as you think. The hinge design is what makes it feel heavy.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 12-04-2010, 02:59 PM
subbieatnz's Avatar
Yes I think that was the case. It supprised me how light it was when I pulled it off my parts car when I wrecked it.
1989 Vortex 6 Maroon
1983 RX Silver Grey
Old 12-04-2010, 03:53 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
don't bother trying to cut anything out. It is nothing but a dusty waste of time. Whar you get out doesn't even equal the weight of 1 strut. Been there done it and still coughing crap up.
Old 12-10-2010, 12:57 AM
Banned
Actual Weight??
Old 12-10-2010, 10:45 PM
Originally Posted by Johnybeas View Post
Actual Weight??
If I can find a scale, I'll weigh one of the 3 that I have laying around
