Old 08-23-2002, 08:20 PM
ehyde111
Thumbs up Finally finished changing spark plugs!
I'll say it was the biggest pain in the rear ever!!! 3 days and 6-7 hours of work for six plugs. Unbelievable. What's up with subaru and that passengers side access hole anyway. THe one in the wheel well is at a good angle from the one in the engine bay. Near useless (I don't have a universal joint). Even if I did, I do not think that it would have worked.
ANyway, I'm done and the car still runs. The biggest casulties were the stripped bolt (would you believe I can't find a replacement -- it's not listed as a separate part -- only comes with the ignition coil -- can't find a match at 3 hardware stores or NAPA) and a burn on my hand. Oh well, they shoudl be good for A WHILE now.
Thanks for listening me go on and on.
Old 08-24-2002, 09:34 AM
svxy's Avatar
svxy svxy is offline
Spark plug hell
When I changed mine for the first time it took me between 2 and 3 hrs, probable closer to two, and that included the learning curve. You learn quickly that conventional socket and rachet use doesn't do much good. You have to connect and disconnect inside the plug area using the socket and extension and forget using a socket on most of the bolts holding the wire in place, a 12mm closed end wrench works much better. The wrench makes it possible not to have to use the "through the fender well hole" method. Still if one of my plugs goes south, it will run that way for a while...my back can't take that contortion again for a while.
96 Red SVX 96,000 miles
02 Toyota Highlander
02 Nissan Altima
04 VW Beetle GLS
Old 08-24-2002, 11:45 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
It took me and two other guys 2 hours. Well one other guy. I had to take out almost everything. Batteries, air filter, you name it. Don't even go to the last one.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 08-26-2002, 08:59 AM
Mr. Pockets's Avatar
Moderator
Re: Finally finished changing spark plugs!
How did you get the stripped bolt out? And if you can't find a replacement, what have you done to secure the coil?
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 08-26-2002, 02:59 PM
ehyde111
Re: Re: Finally finished changing spark plugs!
I was able to unscrew the bolt with a pair of vise grips and a lot of anger. The bolt sed to secure the back coil on the drivers side. It is now on the front coil (I guess it's not stripped, rather the head is rounded off pretty badly) I think I could get it back out with vise grips if a replacement ever comes my way.
