Old 08-29-2010, 01:12 AM
spleen_merchant spleen_merchant is offline
What is this socket for?
Hi,
Found a 3 pin socket on the right hand side of the transmission with nothing plugged into it. Transmission is VTD type. Transmission seems to be behaving itself so can't be too crucial, is it a diagnostic port of some kind?
Cheers,
Jeremy.
Old 08-29-2010, 06:04 AM
Re: What is this socket for?
That's speed sensor 2. Does your speedometer work?
I'm not real familiar with non US transmissions, but on US transmissions, that sensor is needed.
Old 08-29-2010, 08:38 AM
Originally Posted by spleen_merchant View Post
Hi,
Cheers,
Jeremy.
Jeremy
The SVX uses two basic types of transmission, the ACT4 and the VTD. It gets more complicated than that when speed sensors are taken into account.
The ACT4 type as used in the USA [and probably the ACT2 type as well for the FWD models], these use a speed sensor driven from the front diff housing just as in your picture. The AWD gearboxes use 2 speed sensors; one at the rear of the gearbox measuring rear prop shaft speed of rotation, and one measuring the speed from the front diff. These speed signals are compared by the transmission control unit [TCU] to give traction control.
The VTD gearboxes have two different types of front speed sensor. Japanese VTD boxes have the front speed sensor exiting the rhs of the diff housing as in your picture. The rear sensor is the same in all boxes.
UK gearboxes on the other hand although they are also VTD, the speed sensor is inside the gearbox and sends its signal wires out the left side of the casing into the main loom that runs forward to the large square connector. I am fairly certain that Australian VTD boxes also have this internal SS2 sensor feeding the main left hand loom of wires.
If your car is Australian then I would speculate that it may have had a replacement gearbox at some point, and the gearbox used was a JDM one. The JDM box can have the Australian type sensor fitted internally to modify it and make it work with the Australian wiring. If this was done the SS2 coming from the rhs of the JDM diff housing would not be required, and indeed would not have any wiring socket to connect to.
A simpler possibility would be if the diff only had broken on your Australian car. If this was replaced by a JDM differential the SS2 and plug would not be needed, as the SS2 sensor and wiring would already be inside the main gearbox housing.
This is a long-winded answer I know, sorry about that. These bleedin' gearboxes are complicated lumps of metal.
Old 08-29-2010, 05:05 PM
Thanks for the info. I'm thinking whole transmission's more likely. One thing I've noticed is selecting manual mode will hold any gear including first and seems to shift faster than without manual mode selected, whereas I've read elsewhere manual mode's only for holding second to prevent slipping. Is this normal for SVX VTD trans?, or maybe a later Liberty/Legacy GT box?
Old 09-28-2010, 02:35 AM
major7venth's Avatar
major7venth major7venth is offline
M7
I'm still curious if the speedo works?
Old 08-21-2014, 08:26 AM
'E''s Avatar
'E' 'E' is offline
yes it does
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 08-21-2014, 10:48 AM
Wow! 3 years and 11 months for an answer. (Dancing) "Lets do the time warp again".
Old 08-31-2014, 09:40 PM
'E''s Avatar
'E' 'E' is offline
Lol that's because I own the car now and can answer
93 black SVX
95 bright red SVX
